Originally Posted by iceno9
(Post 329903)
Its a long time since i looked at this problem.....but have you cleaned out the throttle body where the EGR valve lets exhaust gases back in? If that valve is somehow stuck in the open position thereby letting too much exhaust gas back into the inlet manifold, you will loose power. From what i remember, its easy to remove and clean with a solvent and should only take an hour or so.
Hi there did you ever get your 487 fault code sorted? And can you advise how you managed it? Cheers |
Originally Posted by Simon Parke
(Post 330172)
