engine light on
Sucks to be #5. Per page 11B-24, #5 is under the intake plenum and furthest from timing belt (driver's side). So in order to test it, the intake plenum must be taken off. Not an impossible job and that action will definitely not void your warranty, so long as it is done properly. I'm sure the plugs would not be under warranty as they do wear over time, however the coil packs I would think would be under warranty. If you have a readout saying #5 is problematic, I'd first confirm that the coil pack is covered, then push to get it replaced by the dealership. If they refuse, then you call Mitsubishi Motors of North America and state you have a readout that states the coil pack is faulty and the dealership is refusing warranty work. That's what I'd do. If they still refuse, I'd even consult with a lawyer who does these types of lawsuits.
Removing the upper plenum involves removal of a lot of little things, but it is time consuming...and combined with labor rates...it'll add up. RockAuto has the coil packs ranging from $55 to $85. I wouldn't know if you can replace just one or you need to do all of them. I'd think since they are individualized, you can just do one.
He said 1.5 hours labor to do all 6 sparkplugs and will swap a coil pack on the #5. If it is the pack, then whereever he swaps it too will throw a code later I am assuming. Pretty cheap labor ($65/h)
Basically mitsu won't cover it. I'm not really pushing this since it states in the book that things like spark plugs and such are not covered anyway.
I'd still verify with MMNA, but at $65 an hour that is pretty cheap. He's exactly right, If you are going to rip into the intake to get back there, might as well change out the plugs and move the coil pack to a front facing cylinder.
what kind of mileage do you have on yours by now? I changed my plugs at 105k and really noticed a boost in power. felt like a new vehicle.
serenabkhan
11-23-2007 05:44 PM
