ETACS options customization
Old 11-22-2013, 03:30 AM
mixchris83's Avatar
yes vadimus rightly .... ie now with lexia 3 kai diagbox 7.19 who I bought I cannot do anything;
  #912
Old 11-22-2013, 07:22 AM
tarkan.dogar's Avatar
Originally Posted by Vadimus
It depends on your location. I know a good supplier in Malaysia, but you're in Turkey I suppose?
you are totally right. i am in Turkey. i appreciate too much if i can get contact info. i think, i can get it by somehow.
by the way, Vadimus, you are really doing a wonderfull job. since we do not have good services in here, your knowladge helped me a lot. i had a lot options already installed and activated with my vehicle. But, some options like remote sunroof and auto lock with speed control was de-activated on delivery. i am working on them now. thanks again, i really appreciate all your works and sharing experiences.
  #913
Old 11-22-2013, 09:10 AM
hi all,
i attached a picture of an info display which indicates rear parking sensor warning on it. do you have that on your display. as a humour, i heard that is an option which de-activated in factory. if so, i will try to activate mine.
edit: I found related link in the forum. sorry for bothering.
Attached Thumbnails ETACS options customization-1235007_589144337803324_1304440763_n.jpg
  #914
Old 11-25-2013, 11:50 AM
legege's Avatar
Anyone has a link to download ETACS Decoder 2.9.x? I want to disable TPMS on my Lancer GT 2012, i guess it would work with this tool + cable kit?
  #915
Old 11-25-2013, 01:35 PM
Vadimus's Avatar
Originally Posted by tarkan.dogar
hi all,
There are like 5 types of factory parking sensor systems for Mitsubishi, not all of them work with cluster display and on every display is capable of displaying these notifications.
Anyway just activation without installing corresponding sensors/harness/ECU won't work
  #916
Old 11-26-2013, 06:36 AM
Thanks Vadimus. We really gonna have a lot things to learn from you. After your explanation new questions rised in my mind. I have factory rear parking sensors but does not appear on my info screen. so, as you explained, there can be two reasons for that;
1. this is not activated (should check by Lexia)
2. parking sensors are not working with this cluster display (i do not know how i can figure out if sensors are correct. do you have any idea?)
Another question is that i am going to add front parking sensors. what shall i do in this case? is there a way to get corresponding sensors?
Thanks a lot...
  #917
Old 11-29-2013, 07:03 AM
legege's Avatar
I've been able to disable TPMS on my Lancer GT 2012. However, I'm wondering if everything is all right.
(SKEY=614)
The initial value read from the car was:
8018120448094007DF006D01C03001441F00228A5221C220C5C1F962EA008242E9A8312 FA794200800000000000000000000A002C059
Now, the value is:
8018120448094007DF004D01C03001441F00228A5221C220C5C1F962EA008242E9A8312 FA79420080000000000000000000000000000
For the value in red, is this normal?
Edit: The value was chopped because of the "encode" function. I decided to append the end of the previous value, and it worked!
Huge thanks to the author of ETACS Decoder, it's amazing!!
  #918
Old 11-29-2013, 07:39 AM
Vadimus's Avatar
Yeah, that's OK to have that part zeroed.
  #919
Old 12-02-2013, 11:40 AM
mixchris83's Avatar
hi vladim. I installed the diagbox v 7.1 when choosing my car it says java script . YOU KNOW something; (ERREUR DE CHARGEMENT DE CELLULE
ERREUR DE CHARGEMENT DE CELLULE: erreur de chargement dans la cellule: Session = Portail SP = 2 Line = 3 Column = 5 File = C: \ AWRoot \ dtrd \ tree \ script_vcistateaobt.s traitement de cellule impossible.
  #920
Old 12-03-2013, 07:26 AM
mixchris83's Avatar
Good evening. the installation of all good. ! I have problems with the Code .. lexia in with 03114 says impossible configuration and the pp2000 is 4 NUMBERS code ... (my car is asx 2013)
Quick Reply: ETACS options customization
