File under stupid: Car alarm blinks the HID's
Hi Everybody
I was testing out the motion detector car alarm the other day and noticed that when it's alarming, it rapidly blinks the HID's on and off...
Uneccessary, repeated strikes is bad for bulb life, no? Also, a just struck HID is super dim, making this simultaneously the worst and most expensive choice if you're looking to attract attention by blinking lights.
Way to go, un-named Mitsu engineer! Your non-attention to detail is astounding.
Can I rewire/reconfigure the alarm to another set of lights? <longshot>Can anybody put me in touch with the engineering team responsible for implimenting the alarm/lighting interactions? I want them to be my facebook friends.</longshot>
![Roll Eyes (Sarcastic)](https://mitsubishiforum.com/forum/images/smilies/rolleyes.gif)
Hi Everybody
I was testing out the motion detector car alarm the other day and noticed that when it's alarming, it rapidly blinks the HID's on and off... Uneccessary, repeated strikes is bad for bulb life, no? Also, a just struck HID is super dim, making this simultaneously the worst and most expensive choice if you're looking to attract attention by blinking lights.
Is your HID factory or aftermarket? What kind of alarm? did you install it? Sorry for the questions but to help you I need some help....
Thanks for the reply. Does your Outtie have factory alarm and HID? I am guessing one is a NO. If so, I hate to knock the engineers of Mitsu, but it is obviously an oversight because it should not be like this. While a very poor (ilbeit easy) way to do a light flash on a factory alarm, your HID's should not be doing this. A stock alarm usually triggers the headlights but to me it is still a no no. Who is me? I have installed aftermarket alarms for almost 2 decades. I am not an engineer but I do know a little about the subject......
Answer my questions and I will do some research and help you from there. I suspect ONE of them is not a true factory install but a dealer add on. If it is the Alarm I can help you more, if not, I will still help you but will probably have to phone a friend..
No aftermarket, all factory-installed.
I don't want a flame but I do have to say that this was a poor design on the Mitsubishi engineers part if this is the case. Sounds like the alarm is the same regardless of headlight option which is REALLY why they should have supervised the parking lights in the first place on the alarm instead of going with the "standard" "flash the headlights" circuit in the first place...........
Thanks for the answer Vadimus. I will have to do a little research on the vehicle wiring on this one to give a safe alternative. Unfortunately, this may not be easily possible or may not be possible without a major mod since I do not know how the stock security is wired/integrated. IF we were talking about an aftermarket alarm system; I would have already provided an answer for the OP but once OEM integration takes ahold...welll.....we will see.
I guess it could be just wrong settings in ETACS. I do not have 2010 Coding List, like the one for 2007-2009 here (no translation needed this time).
I couldn't believe it either... In fact, in automotive engineering circles, they call this kind of design "retarded"
If anybody has the factory wiring diagrams, I'm sure I can figure out a fix. In the meantime, I won't be testing the alarm out anymore. I wonder if it blinks the lights when you arm/disarm it...
salsomano1a
04-08-2012 06:24 PM
edaddik
12-16-2005 05:11 PM
