Firestone 4106 or 4182 airbags?
Old 06-09-2010, 09:33 PM
tcp's Avatar
tcp
tcp is offline
Default Firestone 4106 or 4182 airbags?
I'm having trouble getting the 4182 airbags as they seem to be backordered for at least another month. Anyone use the 4106 kit on their outlander? Any fit issues?
Thanks.
Old 06-29-2010, 03:09 PM
seajack's Avatar
Default Firestone 4106 vice 4182
Installed 4106 ,bladder half inch wider than 4182 ,usable but leaves small crease in bag .Might work out after awhile.I used a "T" fitting so both bladders fill at same time. For "T" fitting goggle "firestone 3025",about $10.
Old 06-29-2010, 10:25 PM
tcp's Avatar
tcp
tcp is offline
Default Thanks
I have the 4106's at home and no T-fitting in sight. I almost think I'll leave the hoses off and just fill the schraeder valves on each bag and just leave things at that. 10-15psi ought to do it about right. not sure yet. depends on how much time i've got.
Old 06-30-2010, 08:26 PM
seajack's Avatar
I dont know if I would like the idea of one bladder leaking and other at full pressure. Could set up a suspension problem and possible tire wear .
rsoto
11-23-2009 04:12 PM
bossup2008
01-15-2008 05:51 PM
sk8dudety
08-13-2007 12:30 PM
tidus10
06-05-2006 12:10 PM
Duce Apocalypse
03-16-2006 03:39 PM
Quick Reply: Firestone 4106 or 4182 airbags?
