Fluids change/flush
Can anyone provide some info on when is the best time to flush power steering and brake fluids. Thanks a lot!
I have heard that the best time to do it is when the car is stationary :D..........seriously, anytime you do it, you are better off than most everyone else. But hey, what do I know as I have driven two cars to over 350K miles without changing those fluids.
brake fluids is generally every 2-3 years.
power steering probably every 4-5 years. I'd definitely change fluids. I had a Grand Am that only had a rack & pinion last 108k miles. I met me now wife when she had it at 80k. If power steering is a dark color...change it. Brakes are easy if you have a suction pump. |
Originally Posted by ccernst
(Post 283731)
Well, you could do the pads without touching the fluid.
And you could do fluid without touching the pads. I actually just did the pads in my own driveway, and am planning to take the car to the dealer to do the fluid. Or maybe I will just take it to a local shop instead. The dealer is kind of far. My Outlander is around 57K miles now. Now when I did my GTO, I took it to a good mechanic and he did pads/rotors/fluid all in one shot. |
Originally Posted by ruski
(Post 283833)
| All times are GMT -5. The time now is 07:32 AM. |
