Fog Light Installation
Pre wired ES?
I have a 2010 Outlander ES that I would like to add fog lights too. It has the covers in bumper, but I dont remember seeing any pre wiring. Anyone know about rhis? Also, satellite radio module preinstalled cause I only see harness for it.
The harness you will connect to is in the center of the front. If you look carefully from the grill, you should see an unused wire harness. This is the kit you should get Part# MZ380538EX. This is OEM.
It has everything you need, including the signal light switch. The cost is around $340.00.
