Fog Light Installation
Old Nov 27, 2003 | 02:40 PM
dasher714's Avatar
Default Fog Light Installation
Has anyone tried to install the Fog Lights on an LS? Is the Outlander pre-wired?
Old Jul 19, 2018 | 03:19 PM
WHITEOUT2010's Avatar
On my 2010 ES. Yes, is is pre wired but it's "plug, code and play". Coding instructions are included with the unit. What year is your car?
Old Oct 20, 2019 | 05:29 PM
Sodisco420's Avatar
Default Pre wired ES?
I have a 2010 Outlander ES that I would like to add fog lights too. It has the covers in bumper, but I dont remember seeing any pre wiring. Anyone know about rhis? Also, satellite radio module preinstalled cause I only see harness for it.
Old Oct 21, 2019 | 10:51 AM
The harness you will connect to is in the center of the front. If you look carefully from the grill, you should see an unused wire harness. This is the kit you should get Part# MZ380538EX. This is OEM.
It has everything you need, including the signal light switch. The cost is around $340.00.
91eclipse
May 7, 2004 08:45 AM
vpleonard
Apr 27, 2004 08:47 PM
taylor61387
Mar 26, 2004 12:30 AM
quicken
Mar 6, 2004 11:37 AM
2fast4u
Sep 6, 2003 06:44 PM
