-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Fuse questions (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/fuse-questions-43222/)
vladguan Oct 17, 2012 08:28 PM
Fuse questions
Hi All,
I have an Australian spec 2007 Outlander XLS 2.4 CVT with fog lights, standard low and high beams and not DRL. I am trying to fit some LED DRLs and have some add-a-circuit fuse taps. I am trying to find the parker lamp fuse in the engine bay but cannot find any. Neigher the book nor the fuse cover indicates there is one. The interior fuse panel also does not have one.
However, I did notice that besides having fuses for low beams, high beams and fog lights, there are also 2 20A fuses for HID low beams. Have not tested these to see what they do.
I have found an ignition switched power source (30A diesel) fuse which only has the +ve pin which I can tap off but will have to splice into the parker light +ve if there is no fuse for it.
Anyone else has come across this?
Cheers,
Vlad
