-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Glove Box cooler/heater switch (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/glove-box-cooler-heater-switch-40246/)
Ian Aug 6, 2011 01:19 PM
2 Attachment(s)
Anybody know where I can buy Glove Box cooler/heater switch ?
I know that I need this two parts :
Shut dial assembly p/n 8042A013
Shut dial hose p/n 7830A084
These 2 parts are not available in Canada and USA
vrx26 Aug 6, 2011 03:40 PM
There is no separate switch for the cooler/heater glove box. The temperature control is basically your climate control (air conditioning). The parts in your post are needed just to divert hot or cold air to the glove box. Hope this helps.
jsrd Aug 6, 2011 08:33 PM
Without doubt, in Japanparts.com - JDM Parts,Performance Auto Parts
For hose, japanparts part number is 403-032-004
For switch, japanparts part number is 403-038-001
Saludos :)
Ian Aug 7, 2011 11:46 PM
Thanks,
I checked in japanparts.com and it is 28.75$ CAD for the hose and
21.25$ CAD for the knob plus 17,95$ for the shipping.
I try to find these pieces elsewhere, but I think is the only place that sell this.
ionicaw Sep 1, 2011 01:12 AM
5 Attachment(s)
after I saw your listing i decided to take a look in the upper glove box and I pulled the stereo out to see how can be done. I found some left over pipe from the kitchen sink and this is how I did mine:
The first time I bought 1.2 inch hose, 1/2 inch 90 and a sprinkler shut dial but it was too small in diameter and the air barely came true just when I had the vents closed. after that I used his pipe and now it does blow lots of air. the only thing is that I'm not able to shut it off just if i unscrew and put a cap instead of the ring.
If you do the same as I did you will need to cut the treads off from the pipe and than cut the pipe again right where the angle start and then glue the treads back ON. In this case you will not have a lot of pipe sticking out inside the glove box and the vent can go back in the place.
for the tip I used a suction cup for now untill I'm building a disk with a lot of holes that goes inside the ring.
hope that helps. It saved me $70 or maybe $65 cause I bought 2 feet 1/2 inch hose 1/2 inch 90 and the sprinkler shut dial that didn't work as good :))
greatcat Sep 1, 2011 10:48 AM
Originally Posted by Ian (Post 275764)
Thanks,
I got them a while ago from China, cost me about $20 CAD.
??|??-?EX|?? ??EX? ?EX?? ? ??
jsrd Sep 1, 2011 11:09 AM
greatcat, you have a e-mail address from your seller contact in China? I want to get some parts of Chinese Outs but I havenīt been able to find a company as japanparts.
Saludos. . .
greatcat Sep 1, 2011 12:25 PM
here is their email from the website:
I just want to clarify that I have nothing to do with them, but as my own experience and the discussions on the Chinese Forums, this guy seems honest to deal with.
FAUEE Sep 1, 2011 12:45 PM
So you're saying that with that hose the airflow was very minimal? The Hyundai Veracruz and Dodge Journey both have cooled compartment covers that look like they may fit (and should be cheaper since they're features from the US) so using an inexpensive pipe to hook up to that could make this a much more affordable setup.
greatcat Sep 1, 2011 12:59 PM
Here are the pics I got from a Chinese Forum "Xcar.com.cn", this guy did everything by himself using the parts you can find in your local store (like Canadian tire / home depot)
http://image.xcar.com.cn/attachments...8rTTZys3zK.gif
http://image.xcar.com.cn/attachments...xXAIBh93ca.gif
http://image.xcar.com.cn/attachments...MxU8DOkCdT.gif
http://image.xcar.com.cn/attachments...APwix7PvZ6.gif
http://image.xcar.com.cn/attachments...fqSX8GCo6N.gif
http://image.xcar.com.cn/attachments...976LqEN2EN.gif
http://image.xcar.com.cn/attachments...IQ0YzSVjnt.gif
http://image.xcar.com.cn/attachments...W7yaCPV3vV.gif
http://image.xcar.com.cn/attachments...DIKrEfKkwL.gif
http://image.xcar.com.cn/attachments...unR5AldVQt.gif
http://image.xcar.com.cn/attachments...QOkVGPzkPD.gif
http://image.xcar.com.cn/attachments...v1FXb7k2vX.gif
http://image.xcar.com.cn/attachments...wc5FhaM7lC.gif
http://image.xcar.com.cn/attachments...oQb9DvfW9g.gif
http://image.xcar.com.cn/attachments...8beAHWI1DG.gif
