Gracenote CDDB update
Old Sep 18, 2007 | 12:34 AM
rcpax's Avatar
Default RE: Gracenote CDDB update
Do you have the US Outlander? what's the build date of your Outlander? I can't believe it does not work for me. I used a CD-RW, ISO9660 with no relax iso extensions, type 1.
what's the cd tree structure supposed to be? mine looks like (X is drive letter)
X:\ECDDB.UDT
X:\CDDB_VER_EN.TXT
X:\ECDDB.UDX
or should it look like this?
X:\1459\ECDDB.UDT
X:\1459\CDDB_VER_EN.TXT
X:\1459\ECDDB.UDX
Did anybody successfully tried using a CD-RW media? that's all I have at the moment. I don't want to buy a CD-R unless I can confirm it works
Better yet, can someone post an ISO or NRG image of their media used? Just post it through Pando or Megaupload, or Rapidshare
Old Sep 18, 2007 | 05:28 AM
uscwrollins's Avatar
Not sure the build date (I will have to check) but I bought it in Oct. 2006. My CD structure looked like:
X:\ECDDB.UDT
X:\CDDB_VER_EN.TXT
X:\ECDDB.UDX
Old Sep 18, 2007 | 05:49 AM
rcpax's Avatar
Did you use a CD-ROM or CD-RW? And also, what program did you use to burn the CD and what are the ISO settings. Somehow I can't update with a CD-RW with the same tree structure.
Old Sep 18, 2007 | 09:05 AM
I used a CD-R and Nero for my burning software (CD-ROM (ISO)).
Old Sep 18, 2007 | 09:36 AM
evoracer's Avatar
I also used a CD-RW with no success. I am getting some CD-R's today to give it another try. BTW I burned it with the built-in Vista program.
Old Sep 18, 2007 | 08:37 PM
antlip's Avatar
I need help too. I downloaded the zip file. Extracted it. Burned the extracted files (3) to a cdr data cd and it didnt work. How do you do it?
Old Sep 18, 2007 | 10:10 PM
bleacherbum's Avatar
I used Sonic Record Now! with a CD-R--but you may have to check your burning app's settings to see how to create "closed" sessions--the disc should not be able to be added to/appended to after you are done. Your default settings may be for "open" sessions for data cds. Otherwise, I suspect your CD-RW media is not compatible for some reason..? In addition--when I first put the disc in--I just got the "Check Disc" warning--it wasnt until I hit "Mode" and saw the active "CDDB Update" button that I realised it might work....
Old Sep 18, 2007 | 10:28 PM
antlip's Avatar
I just did it on cd mode. I put the cd in. It said grace note on the right side. I went to AV mode and waited and waited and waited. Nothing.
Old Sep 19, 2007 | 09:10 AM
evoracer's Avatar
Burned it last night on my wife's pc running XP home with sonic and it worked fine.
Old Sep 19, 2007 | 04:56 PM
antlip's Avatar
How did you burn it?
