H.I.D. bulb replacement
Has anyone looked into the replacement of the HID bulbs for the XLS? Also, any idea on the lifespan of the bulbs?
RE: H.I.D. bulb replacement
Well I can tell you a few things about the HID lights, the lifespan is a lot longer than a standard halogen,but I'm not sure the actual hours of life, but the bulbs are quite expensive at about $100-150 a bulbI believe.
ORIGINAL: dcsr23 Well I can tell you a few things about the HID lights, the lifespan is a lot longer than a standard halogen,but I'm not sure the actual hours of life, but the bulbs are quite expensive at about $100-150 a bulbI believe. |
The lifespan is about 3000 hrs. You can't go out and buy any hid capsule, it needs to be D2R & OEM style plug (not one of the commonly available AMP-type connectors)
