-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Headlight frustration (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/headlight-frustration-57388/)
FrustratedOwner Jun 24, 2024 02:28 PM
Hi all
I hope I'm not the only one experiencing this problem. I have a 2019 Outlander. I am going through headlights every year. It's like clockwork. The right headlight always goes first followed by the left roughly a week later. I've used cheap bulbs, expensive bulbs, even LEDS. I'm actaully considering bypassing the whole circuit and wiring my headlights like foglights. Any suggestions to avoid doing that would be greatly appreciated.
accretian Jun 27, 2024 02:17 PM
Do you have the regular projector headlight that takes h11 bulb?
Do you leave your switch on Auto and drive thru dark places during the day which causes your headlight to turn on for a minute or so then turns off again?
I have the oem led headlight and i always keep my headlight switch off and dont leave it on Auto as i dont want my headlight to keep turning on and off when i go thru tunnels or parkade.. i always control my headlight manually as i believe that it would be better in the long run esp if u have halogen, hid or led bulbs on halogen projector headlight..
The auto headlight in my opinion is for automakers to make money off parts as they would need to be replaced more often.. its convenient for customers but im a strong believer that drivers are the one responsible when to turn on and off their headlights..
FrustratedOwner Jul 4, 2024 03:49 AM
Hi.
Thank you for your response.
I always turn my headlights off. My low beams call for H7 and yes, I'm using the proper bulbs. And no, I am not touching the bulb itself when I use Halogen units.
I've never had so many problems with headlight bulbs in my life, and the dealer has never heard of this, so they tell me.
Truwarrior22 Jul 4, 2024 07:49 AM
Originally Posted by FrustratedOwner (Post 338996)
Hi all
I just use the cheap ones (sylvania). They last longer since they don’t get as bright and warm. I tried bright ones but they didn’t last longer than a year.
