help w/ 07 xls lower front motor mount
Hello all
I havr to replace the lower front motor mount on my 07 outlander xls. This is the mount you see when you open the hood and look straight down under the radiator. looks connected to cross member? Has anyone replaced this and how easy is it? It almost looks like too easy--- floor jack with wood block under motor and take bolts out... im assuming no additional support is needed since UPPER left and right mounts should support the engine-- am I wrong? Thanks very much |
Sounds right to me...
Pics from Manual
2 Attachment(s)
Seems pretty simple. Please post if there's a trick or discovery while doing.
How did it go? I might have to do mine. Any input is appreciated. Thanks!
