Help! Window cable snapped.
Old 03-04-2012 | 12:31 PM
PhilUK's Avatar
Default Help! Window cable snapped.
I have an 04 Outlander (UK). The front window cable snapped on me today and the window jammed. I managed to remove the door panel and free up the window, so at least it is closed.
My question is can I get a replacement cable, or do I need the whole window motor?
Thanks.
Old 03-04-2012 | 02:44 PM
ccernst's Avatar
sounds like you need a new window regulator....something like this:
Mitsubishi Parts | OEM Mitsubishi Parts | Genuine Mitsubishi Parts
usually, the regulator is the cabling & rail assembly the window rides on. sometimes the motor is seperate, so you shouldn't have to re-purchase that. Hopefully there are UK oem mitsubishi parts sites.
Old 03-05-2012 | 04:42 AM
PhilUK's Avatar
Thanks for the information, I will check out local suppliers.
Phil
Old 03-05-2012 | 06:59 AM
matthewm1965's Avatar
I had the same problem with mine a few months ago. I tried to repair it without success. I bought a complete mechanism (without motor) from a local Mitsubishi dealer for about £90 GBP. When I get home tonight, I'll see if I still have the paperwork with the code number on it.
Matt
Old 03-06-2012 | 03:59 AM
PhilUK's Avatar
Thanks for the information. Is this a regular thing with Outlanders?
I have managed to get one ordered from the local Mitsubishi dealer, now all I have to do is figure out how to fit it.
snowchic9
01-27-2020 11:43 PM
JRK5892
09-30-2014 06:40 PM
JRK5892
05-08-2014 11:34 AM
stevet284
11-16-2009 09:14 AM
boristaylor
01-28-2008 04:56 PM
