HID Conversion DONE! (Pics and info)
#151
I got so confused lately, so i'll just ask directly.. My 07 outlander uses non-HID bulbs.. they're halogen bulbs right? the ones that comes from factory.. I'm planing to install HID on the low beams (9006) but there's a diference between H2S and H2R bulbs so, which one is the correct for me? H2S or H2R?
Thanks!
Thanks!
#153
Thanks!
Thanks!
#154
Im not sure if im understanding right. When you say OEM HIDs, most of us would think of just the HID bulb itself. Or do you mean the entire OEM housing, w/ projectors, and HIDs? Such as are on the XLS models?
#155
Sorry - I'm referring to 07-09 with just the reflector HID housing. Would it be worth it to pick up some used XLS headlights to have the proper reflector/beam?
#156
Everyone I have seen is HID inside a Projector LENS.
#158
Okay so i bought an HID kit from Mod-express.com and a drl bypass from ebay (jrox) and so far im overall happy but sometimes i would turn my hids on and the bulbs would ignite, then in less than a sec would turn off. I would have to turn off the hids and then turn them back on a couple times, so that both the left and right bulbs ignite.
I dont have a capacitor, would this help? The bypass unit basically negates the 9 volt from the drl and only when i send the full 12 volts the hids turn on, so basically whenever i want, my HIDS would turn on and I dont have to ride all the time with the HIDs on...
any and all help will be great, thanks!
P.S. this isnt a "major issue" but non the less, id like have it fully functional.. thanks!
#159
I finished the same installation for HID's, but for Low / High beams with two pairs of 6000K. The only differences is that I did not installed the relay harness. Instead, I installed a Warning Canceller set at the low beams to cancel the DRL Flickering effect.
You set the cancellers at the female connectors of the ballasts and the male connectors at the OEM wiring connectors. At the ballasts the Wiring connectors needs to be positive + positive, and at the factory 9006 connector inverted (half twist). Be careful, if correctly installed (warning cancellers) they will be unusable.
Then, the lights works fine as DRL's.
where did you get these cancellers?
