HID Conversion DONE! (Pics and info)
Old 02-10-2010, 05:09 PM
ontariotibv6's Avatar
Originally Posted by xOutlanderFiendx
Hey guys, i have a 2009 outlader SE, i want to install some HID's but i hear if they are too bright you can get pulled over from the cops. In NYC does anyone know what bulb would be good enough without having to worry ?
Just dont go above 4300-5000K, anything higher will just look like blue glare and attract attention. Also get a 35W kit and not 55W. 35W looks much more oem. Search 5000K HID and you will find my post with pics. Good luck.
  #72
Old 04-17-2010, 09:36 AM
euroarek's Avatar
Default HID 55watt
I just got my 55 watt Hid kit for my Outlander 2007 xls...are the relay harness are same for 55watt and 35watt ?? Do I need biger capacitor ..pls help
I wanna buy this relay:
http://cgi.ebay.ca/9005-9006-HID-Rel...ht_2398wt_1165
  #73
Old 04-17-2010, 06:00 PM
ryandlor's Avatar
Those will work, basically all you need is to draw more wattage from the battery.
if you went 35, you wouldn't need to connect to the battery as your headlights already use 35W.
Since you upgraded to 55, you will need to draw a bit of extra power, therefore thats where the relay attaches to your battery bringing in the extra boost more or less.
Any pics once ompleted would be nice...
  #74
Old 04-29-2010, 04:16 PM
Outlander Pilot's Avatar
Default 2010 Outlander
Will I have the same problem with a 2010 Outlander SE?
Brand spankin' new! Picked it up Sunday 4/25/2010
Thanks...
James, NY
  #75
Old 04-29-2010, 06:40 PM
ryandlor's Avatar
Thanks...
James, NY
what problem..theres a few
  #76
Old 04-29-2010, 11:32 PM
Based on what I read so far, installing an HID Kit on Outlander equipped with DRL's has its issues but theres a few ways around them. I guess what I want to find out is, how can I install the kit and only turn them on when I want too.
  #77
Old 04-30-2010, 08:27 AM
ryandlor's Avatar
I wish I knew the answer to that....
  #78
Old 05-01-2010, 04:47 AM
Default enough sitting... more doing
I will try to find out how to 1) disable the DRL so you can install an HID kit w/o any relays, and/or 2)redirect the DRL from the lows to the highs...
Any success, or failure will sure let everyone know.
peace out! see you when i see you...
James NY
2010 Outie
  #79
Old 05-01-2010, 02:51 PM
ivanz's Avatar
What happens when you remove the DRL relay in the engine bay fuse box? Wouldn't that solve it?
  #80
Old 05-02-2010, 12:40 PM
Mitsu28's Avatar
Thanks James, I'm still trying to find out something about it too! I'm leaving in Canada, but the same relay works for DRL and normal low beams...Anyway, waiting for some news!!!
Quick Reply: HID Conversion DONE! (Pics and info)
