How to improve headlight performance?
Daughter is very disappointed with headlights on her 2006. Wondering about bulb replacement, vs HID conversion, vs just adding driving lights. opinions?
do outlander's 2006 have projector lamps?
Originally Posted by ryandlor
(Post 269685)
If they are the original bulbs, (5 years old), then I would replace them for sure. Bulbs loose brightness overtime, and you should see a good difference with any replacement bulb.
Like cheech says, sylvania makes some great bulbs. I have used them in most of my cars over the years. Lifespan is the only disadvantage. I typically get 1 - 2 years before I have to replace them. Cheech, you said you like the phillips x treme bulbs too, but they are not as white. Do they have a yellowish or blueish tint to them? Blue I can live with, yellow drives me crazy. |
Originally Posted by rip14
(Post 269768)
We have replaced the bulbs, but can't remember the brand. I'm sure it was just an off-the-shelf at a local auto store. They are sooo bad, I don't think a 20% improvement will cut it. The lenses don't really look hazed/yellowed - at least not as significantly as you'd expect by the light output. Guess I'll try polishing them and new bulbs.
you can try eurolite lights
Does this model have plastic headlight "glass"? A friend had the same complaint. Her headlight lenses were all cloudy. We cleaned them up with a kit from NAPA. Made a big difference. Just a thought.
Drive Safe Check6 |
Just one word:
XENON |
