How to remove cabin filter?
Can someone please explain? Thanks.
RE: How to remove cabin filter?
I think It's inconvieniently located behind the glove box. You have to
remove said glove box to get to it. If you are mechanically inclined and have never done it, set aside about 2 hours. After the first time, maybe 5 minutes. Or just have the dealer do it when you go for a tune up. |
Whether mechanically inclined or not, it should take no longer than 5 minutes. The glove box pops out in a few seconds once you unhook the side stops. From there, you'll see a rectangular shaped section in the heater (hvac) unit with 2 phillips screws on each end. Remove the screws then pull out the filter. Its going to look NASTY!! Button it back up by reversing the above steps.
Joel, CA |
Can you buy one from an autoparts store or is that a stealership kinda thing?
I got mine from the Dealer.........
Whatca got and how much did it run you?
I just asked for a replacement filter and they gave it to me no charge....I get pretty hooked up with things like this at the dealer I go to.
i only see three screws and from their im lost. is the box that yall speak of right in back of the glove box. or do you have to disconnect the levers and then open the box. Also why do they call it a glove box when no one carries gloves, and why a box, it is not even the right shape
Hahahahaa......
Wait, who said just 5 minutes? |
