How to replace.?????
Old May 9, 2008 | 04:36 PM
Printerman's Avatar
Default How to replace.?????
Hi all:
Would you please tell me how to remove the Map Light Covers...I want to replace them with Leds..
I don't see were to pry them off...
Thanks for your help.....
Old May 10, 2008 | 06:05 AM
rtrackr99's Avatar
Default RE: How to replace.?????
Some illustrations are in your manual.
Old May 10, 2008 | 07:54 PM
ruchuck's Avatar
I would like to do the same thing. where can I get some good LED's? Will they look nice?
________
electronic cigarettes
Old May 10, 2008 | 08:28 PM
Printerman's Avatar
Hi ruchuck:
This is where I ordered my Leds...
They have a 6 or 8 Led unit....
I ordered the 4 6 Led units.....They are called "Festoon" Leds.....
I should have them soon....
http://autolumination.com/festoon.htm
Old May 10, 2008 | 08:32 PM
ruchuck's Avatar
Thanks Printerman.
Did you get the white 31mm ones? What is the advantage to having the LED's? Do they look better?
________
Lincoln Sport history
Old May 11, 2008 | 08:57 AM
Printerman's Avatar
Hi ruchuck:
Yes I ordered the white 31mm... (6Led)
Every posting I saw says they are brighter....
When I get mine I will let you know....
Old May 11, 2008 | 06:00 PM
kcaudell's Avatar
Printerman..... just pull the aft edge of the whole assembly down and it snaps out of the headliner. It pulls straigt away and hinges at the front edge and then the whole assembly pulls out. Very simple. I was looking at it and pulled it down while driving and then put it back up. Put the front edge up first and then snap the aft edge back up into the headliner to reinstall. When it's out, the lights are easily changed out of the assembly.
Old May 13, 2008 | 10:10 AM
Printerman's Avatar
Hi ruchuck:
I put the Led's in today....They are a bit hard to put in. They are a bit bigger than the OEM bulbs...
They work great and are a very bright white....I have the 6 Led units.....It took about 20 min to put them all in so it's not a big deal to put them in....
joeg
18
May 24, 2012 05:29 PM
Lil red
Oct 4, 2005 10:19 PM
dsm16gawd1984
Jul 9, 2005 11:39 PM
jmms
Mar 18, 2005 10:53 AM
bcolins
Jan 31, 2005 02:58 PM
