How to unlock MMCS
Old 11-15-2018, 01:14 PM
Rodderz's Avatar
HI all , any live links for the download? Thanks in advance.
  #662
Old 05-09-2020, 08:02 AM
Richard Szabo's Avatar
Originally Posted by konohakyuubi100
I have a 2015 outlander PHEV Japanese imported with the j-13 MMCS. Do anyone know how to convert this to english.
It has no HDD only 2 SD card slots.
One slot has a SD card which is inaccessible via the computer.
Tried out these instructions for how to unlock the MMCS navigation SD card and it actually worked! After the quick procedure I could easily back-up and change the contents of the SD drive, just like an ordinary SD card. I ended up copying back my old map and it worked without any issues. This is the first method I found that actually works for the SD card models ... https://tinyurl.com/y7665gc
  #663
Old 09-25-2020, 02:58 PM
criStyian's Avatar
Originally Posted by erikphilips
Small update to my previous post, the Intel Password Textbox is limited to 32 characters.
Well I got it working... unbelievable. I had to write a program to write the original values which are outside of human readable text to the clipboard to paste the value in the window. In order to get the correct values in the clipboard I had to use Code Page 1252 (http://en.wikipedia.org/wiki/Code_page_1252); No more using XboxHDM 2.2 !!
I have a small YouTube Clip showing it in action.
Hello,
Does anyone know the exact steps to unlock the drive using the above method with Intel Rapid Storage app? From what I read here, Intel Rapid Storage has an Unlock Drive function built in but I'm unable to install the program.
I have to use this method because I don't have an old pc/laptop anymore and none of my friends have.
Is this even possible or I'm doing something wrong? (I saw in the video that it works and in another post are the passwords for those three types of file system).
  #664
Old 02-23-2021, 08:41 AM
Parts's Avatar
MitsubishiPartsDept.com
  #665
Old 04-19-2021, 06:04 PM
eph's Avatar
eph
eph is offline
Hi, that tinyurl is not valid any more. Have you got the original link please? Thanks
  #666
Old 10-03-2022, 05:58 PM
Eschutte1's Avatar
Default GPS Map
Originally Posted by Benckj
I still need to do my homework by reading through this thread properly before I attempt any upgrade. Last thing I want is to stuff up the system and can't get back to start.
First thing is to get it into English then I'll look at GPS maps and then TV. If I can get all of this working for NZ I'd be very happy.
Jim
Hi Jim,
Did you ever get this to work? I have the J11 and managed to get it converted to English. But I need the NZ GPS Maps
Tx
  #667
Old 06-19-2023, 11:12 PM
Milet's Avatar
Originally Posted by Eschutte1
Hi Jim,
Tx
Did YOU get it working? Im in same boat as you
  #668
Old 07-24-2023, 08:58 AM
adibozi's Avatar
I know this post is old but where can I find the unlock package/software to unloch the HDD, please?
  #669
Old 07-25-2023, 01:51 PM
W@zfa(3's Avatar
J-01 eng
https://mega.co.nz/#!HJFlCCia!yKWQzR...7j0lvNyk-wGZyo
Remove HDD from MMCS
Remove battery for minimum 10 minutes
Connect to IDE of PC (MMCS drive only)
Boot from CD XBOXHDM
Choose option 3 ‘boot linux with locking\unlocking utilities.
Wait for Root@Xbox-HDM:/1 Prompt
Type command
unlockhd –p <KEY>
this is the J-01 Key I used
B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEB5B2DFB19E8996 DFAA8C9A8DDFDF
If completed successfully typing command fdisk –l will show the partitions
Turn off pc
Run Windows with MMCS HDD connected
Locate Loading.kwi on partition with folder screendata.
Backup the original loading.kwi then replace with the new one
Reinstall HDD into car
Reconnect battery
  #670
Old 07-27-2023, 02:33 PM
adibozi's Avatar
cheers buddy
brian360
08-03-2023 01:23 PM
Timmy5
09-07-2013 10:49 AM
96gtrlm
02-28-2008 08:07 PM
bsal
09-18-2006 06:05 PM
endeavor16711
08-06-2006 10:52 PM
Quick Reply: How to unlock MMCS
