If I disable my "check engine light" without getting the issues repaired, will the li
HI.
I got a error code P0304* "No. 4 cylinder misfire detection system", on my Mitsubishi Outlander 2005 mod 4G63-Turbo 201 HP. I thought I had fixed the problem, and reset the engine light with an OBD scanner. I still think the problem is persistent, but the engine light does not come back on. Does someone know if the light will go back on, when the problem is persistent? Thanks. |
