Independent Fog Light Mod
Greetings!
Has anyone been able to make the fog lights independent of the lights for an Outlander? I have a 2010 Outlander XLS AWD V6 Right now, the lights have to be on in order to use the fog lights. I am looking to make them independent of the driving lights. Much appreciated! |
If you are comfortable doing your own wiring, I had an idea to add fog lights to my '07. I stopped because I didn't have the full assembly to make it look right...and didn't want to spend the money to get there. Try some searching in here. it was discussed a few years ago that you could buy something like '01-'03 Diamante fog light buttons that will fit right into the button panel where ASC is turned on/off. Use an ACC source and run a single wire into the engine bay to a relay that runs both fog lights. Disconnect the OEM wiring as that won't be used anymore.
As far as I know, you can just get a Lexia device and set an option in the ETACS to have the fog lights turn on even with the headlights off.
See here: https://mitsubishiforum.com/forum/mi...ization-40223/ |
Originally Posted by ep260
(Post 304981)
See here: https://mitsubishiforum.com/forum/mi...ization-40223/ Does anyone have a Lexia device near Sacramento, CA ;) |
Originally Posted by Cali Duck
(Post 304982)
Wow, that's pretty cool...what does said "lexia" device go for? If it's over $100, I don't think I'd consider it...
Does anyone have a Lexia device near Sacramento, CA ;) Also, for other people who may have the device: https://mapsengine.google.com/map/vi...A.k5jl_k5KAMjQ |
Well now I feel like an idiot. My fogs will operate when the parking lights are on, so I'm all good! I just tested this morning and realized this. Oops! Good enough for me, I just didn't want my driving lights on when its foggy. The fog lights to a better job cutting through it.
UPDATE: I don't know why I thought this worked, must have been early morning or something, but my fogs do not work with the parking lights on. They will only work when the lights are on. |
