LED Floor illumination Outlander Sport?
Has anyone figured out how to install the floor illumination kit? Is there a terminal specifically for this? If so I would like to tap into it for my own set of LED strips. Anyone have experience with this or installed LED strips in the Outlander Sport?
i have been looking into doing this, but havent gotten around to it. have you checked the service manual?
anyone install floor lights period?
I poured over the service manual and I do not see any mention of how the floor illumination kit is installed. In the end I decided to install my own LED strips using an Add-a-Circuit to get +12v to them and grounding them at the dome light switch wire. I was going to add a relay for a manual switch but decided it was too much of a hassle. A little later on I can provide a more detailed tutorial, but that will probably wait till i get my side emitting DRLs installed.
Originally Posted by Jmant83
(Post 275400)
I look FORWARD to seeing this tutorial !!!! :D I would try it myself but the tutorial will help a lott ! |
Required Materials and tools
******************************** Quick Splice for Ground wire: Quick Splice Connector with Male Disconnector (3-Pack) - RadioShack.com Add a Circuit for constant +12v with 5 amp fuse: Cooper Bussmann/ATM fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHH-RP) | Fuse and Accessories | AutoZone.com Wire: 20 gauge speaker wire is sufficient 1/4 inch heat shrink: Dorman/Conduct-Tite 1/4 in. x 8 ft. black heat shrink tubing (85265) | Heat Shrinking Tube | AutoZone.com Connectors: 1/4 inch male/female crimp quick disconnects. 1 Hair dryer 1 Metal Clothes hanger Wire stripper Needle nose plyers Optional components if you want a manual switch as well ************************************************** ******* Optional Relay and harness: 5 Pin 40 Amp Relay 5 Pin Relay Harness Optional Switch: SPST 16A 125V Illuminated Round Rocker Switch with Red LED - RadioShack.com |
Originally Posted by jmant83
(Post 275523)
:d |
you also mentioned side emitting DRLs, can you elaborate on what exactly your going to do with ur DRLs?
Originally Posted by xOutlanderFiendx
(Post 275534)
They will go on the top side of the headlights to act as day time running lights. I think a few others on this forum have done this as well, I will post a tutorial on that in another thread when it is completed. Just waiting on V-LED to release those.... the sales person says they should be coming out very soon. I finished the install of the floor board lighting yesterday. I will take pictures and a video of them in action to go along with the write up. |
