LED Foglights
Old 09-04-2013, 04:06 PM
Burtonrider10022's Avatar
Depends on how large the LED lamp is and how often you tow. If you are mostly an easy driver and don't beat on the trans or tow frequently, and the lamps don't block TOO mush air flow you should be OK. It will all come down to using your best judgement, but if you post up some pics of the lamp just set into the opening it would be best.
Well, interfering with the air flow to the transmission is not wise. It's best to keep the tranny as cool as possible. If you end up installing them in the vents, be sure to remove them if you have tranny problems!
Have you all seen the new OSRAM LEDriving DRLs? They're designed to fit in most round fog light openings. Best of all, they serve 3 functions: fog lights, daytime running lights and cornering assists. Here's a video of them in action:
Old 09-04-2013, 04:35 PM
SERPENTOR's Avatar
Old 09-09-2013, 10:18 PM
SERPENTOR's Avatar
They fit perfectly into the little wholes and do not block the air flow Paid 135 for the installation at bestbuy
Old 09-10-2013, 12:25 AM
Really? No pics?
theiss2200
09-12-2019 08:07 PM
SERPENTOR
08-04-2011 07:52 AM
letsstophere
04-26-2006 01:07 PM
Greenday099
03-06-2006 12:50 PM
boltex55
01-12-2006 05:34 AM
Quick Reply: LED Foglights
