Light Bulb Replacements
Old Jul 15, 2012 | 12:27 AM
Gen-8's Avatar
Post Light Bulb Replacements
Sticky please Mods
Light Bulb Replacement List
feel free to add your findings to the list too pleae so we can ensure accuracy of the information
2011 Mitsubishi Outlander Auto Light Bulb Sizing Chart
Low Beam Headlamp Light Bulb Size: 9006 or 9006 HID Upgrade Kit,HID JDM-D2R 35W
High Beam Headlamp Light Bulb Size: 9005 or 9005 HID Upgrade Kit
Parking Light Bulb Size: 2825, BA9
Front Turn Signal Light Bulb Size: 992 (7440A),WY21W
Rear Turn Signal Light Bulb Size: 992 (7440A),WY21W
Tail Light Bulb Size: LED
Stop Light Bulb Size: LED
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: H11
License Plate Light Bulb Size: 2825,Ba9
Back Up Light Bulb Size: 7440,W21W
Front Side Marker Light Bulb Size: 2825
Rear Side Marker Light Bulb Size: 2825
Front Map Light Bulb Size:3022 31mm Festoon
2nd Row Passenger Interior Light Bulb Size:3022 31mm Festoon
Rear Interior Light Bulb Size 3022 31mm Festoon
if anyone knows the new names or replacement bulb sizes please add and ill update aswell
how do i save word docs as png etc for Mitsi Wiki?
Old Sep 1, 2012 | 01:43 AM
lbs143's Avatar
One name is:
PIAA Intense White Bulbs - 10926
Oil Filter
Old Aug 6, 2013 | 07:38 PM
gord888's Avatar
Thought i'd revive this thread for those of you who want LED bulb replacements on the cheap. These are ones I've purchased and used on my Outlander. They are all as bright or brighter than stock with the exception of the rear license plate bulbs which were a tad dimmer than stock.
Front marker bulbs:
T10 1.62W 117lm 585nm 9-SMD 5050 LED Yellow Light Car Clearance Lamp (12V / 2 PCS) - Free Shipping - DealExtreme
Rear marker bulb:
PointPurple F924R T10 2.4W 72lm 635nm 24-SMD 3014 LED Red Light Car Lamps - (DC 12V / 2 PCS) - Free Shipping - DealExtreme
Reverse bulbs:
YT1311282 T20 6W 400lm 15-SMD 5730 LED White Light Car Foglight / Brake Light - (DC 12~24V) - Worldwide Free Shipping - DX
Sun Visor bulbs:
0.4W 3-SMD 5050 LED White Light Car Sun Visor Lamp (2 PCS) - Free Shipping - DealExtreme
License plate bulbs:
T10 60~70LM 6000~6500K 5x5050 SMD LED White Light Bulbs (24V / Pair) - Free Shipping - DealExtreme
Interior dome bulbs:
I used the 8LED version, but those are not longer available. the 6LED will work just fine.
SV85 31mm 0.5W 6500K 65LM 6-SMD LED White Lights for Car (Pair / 12V) - Free Shipping - DealExtreme
Old Aug 6, 2013 | 11:50 PM
RVR's Avatar
RVR
Hello. Do u happened to know by any chance of all the led light bulb replacements for the new 2013 mitsubishi rvr gt. thanks.
Old Aug 7, 2013 | 11:06 AM
Burtonrider10022's Avatar
Bulb size chart (LED ready) - evolutionm.net
Those are for the US Spec Outlander Sport, but hopefully it helps
Old Aug 7, 2013 | 02:42 PM
OutlanderGT's Avatar
Does anyone know what type of bulb is the day time running light on the full size outlander, they are closer to the grill and a halogen light
The actual "night" light is factory HID, so they can't be the same bulbs?
Old Aug 7, 2013 | 05:43 PM
RVR's Avatar
RVR
Thank you for that info. I'm assuming that u r taking about the 2013 and If it is the same year outlander sport. The size of the bulbs should be the same for the Canada spec.
Old Aug 9, 2013 | 01:10 AM
Well, technically it was made for the 2011, but I literally JUST updated it with the best info I have for the 2012 and 2013 model years.
Old Oct 19, 2013 | 06:51 PM
philmiami's Avatar
Hello all.....
I have a 201 Outlander (the full sized one) and those side marker lights on the bumper on the rear......well I can NOT figure out how you would replace those light bulbs.
I opened the rear door, lower the rear part of the door....did not see some screw or anything to loosen the housing.
I just wanted to know if anyone had a way to do that?
I want to replace all the lamps in the car with LED like on my 2011 F150.
I ready changed the front headlights low beams to HID 6000k and the fogs to HID 4000K (they look yellow like European fog lamps). I will leave the high beams as halogen as a backup if the HID ballast fails or lamp burns out.
This is my wife's vehicle, but I prefer LED because it's just brighter and easier on the eyes at night.
Any input would be helpful...
thanks
philmiami
Old Dec 13, 2013 | 02:19 PM
brianwis's Avatar
I would like to see this updated for the MY 2014, as the owners manual doesn't list the part number of the bulbs any longer, just the wattage. Anybody?
