Light Bulb Replacements
Sticky please Mods
Light Bulb Replacement List feel free to add your findings to the list too pleae so we can ensure accuracy of the information 2011 Mitsubishi Outlander Auto Light Bulb Sizing Chart Low Beam Headlamp Light Bulb Size: 9006 or 9006 HID Upgrade Kit,HID JDM-D2R 35W High Beam Headlamp Light Bulb Size: 9005 or 9005 HID Upgrade Kit Parking Light Bulb Size: 2825, BA9 Front Turn Signal Light Bulb Size: 992 (7440A),WY21W Rear Turn Signal Light Bulb Size: 992 (7440A),WY21W Tail Light Bulb Size: LED Stop Light Bulb Size: LED High Mount Stop Light Bulb Size: Assembly Fog/Driving Light Bulb Size: H11 License Plate Light Bulb Size: 2825,Ba9 Back Up Light Bulb Size: 7440,W21W Front Side Marker Light Bulb Size: 2825 Rear Side Marker Light Bulb Size: 2825 Front Map Light Bulb Size:3022 31mm Festoon 2nd Row Passenger Interior Light Bulb Size:3022 31mm Festoon Rear Interior Light Bulb Size 3022 31mm Festoon if anyone knows the new names or replacement bulb sizes please add and ill update aswell how do i save word docs as png etc for Mitsi Wiki? |
Hello. Do u happened to know by any chance of all the led light bulb replacements for the new 2013 mitsubishi rvr gt. thanks.
Originally Posted by RVR
(Post 294840)
Those are for the US Spec Outlander Sport, but hopefully it helps |
Does anyone know what type of bulb is the day time running light on the full size outlander, they are closer to the grill and a halogen light
The actual "night" light is factory HID, so they can't be the same bulbs? |
Originally Posted by Burtonrider10022
(Post 294847)
Bulb size chart (LED ready) - evolutionm.net
(Post 294859)
Thank you for that info. I'm assuming that u r taking about the 2013 and If it is the same year outlander sport. The size of the bulbs should be the same for the Canada spec.
Hello all.....
I have a 201 Outlander (the full sized one) and those side marker lights on the bumper on the rear......well I can NOT figure out how you would replace those light bulbs. I opened the rear door, lower the rear part of the door....did not see some screw or anything to loosen the housing. I just wanted to know if anyone had a way to do that? I want to replace all the lamps in the car with LED like on my 2011 F150. I ready changed the front headlights low beams to HID 6000k and the fogs to HID 4000K (they look yellow like European fog lamps). I will leave the high beams as halogen as a backup if the HID ballast fails or lamp burns out. This is my wife's vehicle, but I prefer LED because it's just brighter and easier on the eyes at night. Any input would be helpful... thanks philmiami |
I would like to see this updated for the MY 2014, as the owners manual doesn't list the part number of the bulbs any longer, just the wattage. Anybody?
| All times are GMT -5. The time now is 07:30 AM. |
