made my own DRL set up
so as i posted a while back, i did HID and in order to pull it off i used the running lights as my power source for my ballast. In doing this I eliminated the need for factory headlight harness and lost DRL function... been driving me nuts figuring out what to do...
Then I remembered i have a set of LED lights i got free with an item a few years ago... (same as these pictured) 2X 12V DC Car Daytime Running Light 8 LED DRL Daylight Head Lamp Super White | eBay http://image.pushauction.com/ViewPic...2-9af7930e08c0 under our rigs there is a cut out from some of the plastics and these suckers fit right in there like it was made for it, I just had to pull the 3 push pannel pins around the area to get it to fold down, drill my 2 holes in the plastic and bolt everythign up https://fbcdn-sphotos-b-a.akamaihd.n...4aa4d126571d32 i then ran wires for them both UP along the inside of the engine bay , soldered them into 1 main line around the radiator area, and then soldered everything into this adapter below Car LED Daytime Running Light DRL Auto on Off Controller DC12V | eBay http://img.dtmas.net/w10/x23/p55/bl297_2.jpg the adapter is pretty cool, i was able to splice the white line into the power line for the HID set up off the running lights, soldered and shrink wrapped that all up, then did the same for the power/ground to the running lights. From there hooked up the possitive to the battery and grounded the negative out on the frame. Nice think about these lights is they are on full power when the lights are off, when the lights come on they cut to 1/2 power and become marker lights, then when the car is turned off they stay on for about 20 seconds before shutting down. all in all i have maybe $15 into this whole thing, looks super clean. I will say it is all but IMPOSSIBLE to get pictures of these suckers. When the headlights are on they really are more like marker lights, even though they picture like they are full bright. but figured i would share. Nice thing about them going to 1/2 power is in becoming marker lights they also allow you to remain legal (only allowed 4 forward facing lights on the road) so this way i am not getting pulled over for some BS. daytime running lights https://fbcdn-sphotos-c-a.akamaihd.n...4471e92aef13cd headlights on and DRL at 1/2 power https://fbcdn-sphotos-e-a.akamaihd.n...686dbd2bec15e8 headlights, grill lights, fogs on, and DRL at 1/2 power https://fbcdn-sphotos-d-a.akamaihd.n...ffcaacd058d3a3 some really bad overly bright photos i snapped with the cell https://fbcdn-sphotos-f-a.akamaihd.n...099c393da2d909 https://fbcdn-sphotos-h-a.akamaihd.n...33595f0eeca653 https://fbcdn-sphotos-b-a.akamaihd.n...526e937c6199e6 |
well... the ****ty LED driving lights went... go figure right... so i redid them a bit different, used 9w eagle eyes this time...
i know they look crooked in the pics but they are perfectly strait https://fbcdn-sphotos-a-a.akamaihd.n...6738368861ed51 DRL https://fbcdn-sphotos-g-a.akamaihd.n...dd8685a5a55b06 60% power DRL with headlights https://fbcdn-sphotos-a-a.akamaihd.n...ca0621e64aff97 https://scontent-b-ord.xx.fbcdn.net/...25&oe=54B132F6 with fogs on and grill lit https://scontent-b-ord.xx.fbcdn.net/...77&oe=54ECDE76 https://scontent-b-ord.xx.fbcdn.net/...c3&oe=54E97BDE |
Nice! What's the story on the HID setup? I was bummed to find that the Outlander didn't have HIDs where as the OSport does. Were some Outlanders available with HIDs?
Originally Posted by stvOuttie
(Post 305351)
Laws over your way may be different, here they must be auto-leveling and be fitted with washers. Also remember that if you are looking at sourcing them from another country, the cutoff plate could be wrong (right-hand drive vs left-hand drive) |
(Post 305351)
https://lh6.googleusercontent.com/--...116_200159.jpg |
I have hunted for HID pojection lights for my outie... can not find them anywhere for under $400, i plan on doing a retro fit this winter and building my own headlights... i have done this on every vehicle i have owned now... for my HID, i did it a bit different than most because i kept blowing ballasts with the power changes, even with the flicker box, and relay set up... so i tapped my power souce off the running lights to turn on and off the ballast. The way the lights are aimed they do not offer flood HID lighting and it does not blind people. i actaully had it tested at the local police dept about 4 weeks ago and it passed with flying colors. (my ****ty liscense plate LED's that on occasion flicker however failed due to the flicker)
I did my HID very simply, first split the wires to the running https://fbcdn-sphotos-c-a.akamaihd.n...cff50dd7a0f49a https://fbcdn-sphotos-e-a.akamaihd.n...4d3d0c45939670 https://fbcdn-sphotos-h-a.akamaihd.n...b4263aded8950c for my old jeep i opened up a set of aftermarket lamps on it and built a HID set up... i hated all the blue LEDS in it when i got it and the lame ass reflector inside stuck out like a sore thumb, so i swapped wiht all plasma white, and did a 6k hid kit https://fbcdn-sphotos-c-a.akamaihd.n...fafd67922faa3e https://fbcdn-sphotos-f-a.akamaihd.n...caae382a3c2dde https://fbcdn-sphotos-d-a.akamaihd.n...c98c73edaecc5e https://fbcdn-sphotos-c-a.akamaihd.n...80eb5645ea4c24 all done with PIAA fog lights https://fbcdn-sphotos-a-a.akamaihd.n...99c3901afee0e4 https://fbcdn-sphotos-e-a.akamaihd.n...920e9c860a6f17 https://fbcdn-sphotos-h-a.akamaihd.n...b48da5de4bb09f |
Originally Posted by JRK5892
(Post 305378)
...building my own headlights... i have done this on every vehicle i have owned now..
...i actaully had it tested at the local police dept about 4 weeks ago and it passed with flying colors. |
chicago IL, they did a height measure, color temp measure, and some test he called flood lighting... my guess would be the amount of light that is not aimed as it was done on a black wall with point markers all over it.
i will also add that my headlights are propperly aimed. never ever had a buddy or just a person driving tell me my lights where blinding either on coming or behind, granted i will still build a retro fit, just cause i like the looks and want to color match the inside of my headlights... but they are not blinding by any means. I leave my shop around 3am every day, i do get pulled over pretty often as i pass right though the main strip of town with all the bars... never EVER had a cop say anyting at all about them...
| All times are GMT -5. The time now is 03:04 AM. |
