-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Mitsubishi 3.0L V6 Outlander Timing belt replacement (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/mitsubishi-3-0l-v6-outlander-timing-belt-replacement-48446/)
Ilya Nerush Jul 4, 2015 01:02 PM
Mitsubishi 3.0L V6 Outlander XL Pajero Sport Challenger Timing belt replacement
http://www.youtube.com/watch?v=lkG396-0Y7E
gggplaya Jul 5, 2015 09:33 PM
Awesome thanks, i'm doing mine later this summer.
ccernst Jul 7, 2015 10:16 AM
since that vehicle has the engine removed...it is missing a lot of steps. Biggest one...removing a motor mount while the engine is still in the vehicle.
gggplaya Jul 7, 2015 10:57 AM
It shows reinstalling the motor mount. All that stuff should be straight forward anyways.
ccernst Jul 7, 2015 11:11 AM
Removing the motor mount is not a problem...a bolt or two and done. the problem becomes the engine that needs that support in place. They have the engine on a stand that does not need the mount. when the engine is in the vehicle...you kinda need it. :D depending on how the person is doing this work, you need to account for that. I had a 4-point lift and supported the engine with a floor jack. if you are trying this in a drive way...you need to lift the vehicle while also supporting the engine.
Le@r Jan 29, 2020 03:46 PM
thanks
