MMCS Feature Requests
Now that we're successful in patching the software used in the MMCS navigation system for the NR-261UM and NR-261EM used on the Lancer & Outlander, what kind of features do you want to see added/changed?
Here's a TODO list so far: [ul][*]DVD Video in motion [patched NR-261UM NR-261EM][*]AUX Video in motion [in progress][*]Navi disclaimer screen disabled [in progress][*]MP3 Playback from DVD and/or directly from HDD[*]Force "Manual" reset mode for average speed and MPG indicator[*]"Smarter" backlight brightness modes[*]DVD Region Free[*]Ability to use any hard drive (and larger capacity for music server)[*]Prevent HDD from being locked[*]"Advanced" GPS Status screen, with GPS altitude and GPS Speed display[*]View reverse camera at times when not in "Reverse"[*]Add "missing" RDS feature to USA models
[/ul]
[/ul]
How about a list of what is possible?
I for one wouldn't mind being able to 'flip a few bits' on some options I want then update. For me the DVD playing is a take it or leave it option. But the OK button would be great, along with fixing the bug with the display brightness.
Perhaps a template or xml file we could just enable/disable options?
(or am I asking for to much)
... and thanks for all the effort it is appreciated.
ORIGINAL: brian360 [ul][*]AUX Video in motion[/ul]
ORIGINAL: brian360 [ul][*]Navi disclaimer screen disabled[/ul]
ORIGINAL: brian360 [ul][*]MP3 Playback from DVD and/or directly from HDD [/ul]
Also : A description of what you're after would be useful - please remember I don't have one of these units : I'm basically working from touch here ..
ORIGINAL: Outie08
How about disable the auto reset for mileage
ORIGINAL: Otaku
ORIGINAL: sbessel
One thing I've always found annoying is no way to force a bright screen when I drive in the daytime with my lights on.
My list of modifications that I would like to have in the MMCS are:
- RES video in motion
- Time in format of 24 hours,
- Visualizes simultaneously, longitude, latitude and altitude in the same screen
- In the screen where the altitude visualizes, to replace info "ALTITUDE" with the inside temperature, if it will possible
- Dimming of the screen when light position turn on, MANUAL activacion, no AUTO
- Active TV function on MODE screen
- Option to activate the camera of reversa at any time
- ELIMINATE REESTRICTION 99 SONGS PER PLAYLIST
- The possibility of edit name to the radio stations; at the moment only it shows the number of frequency. . .
- The possibility of RDS
I'm not sure if this is the same as Aux-in-Motion, but I would like to be able to view my back-up camera while driving. Mine is hardwired into the MMCS per the rdennis instructions. The only time it comes on right now is if I am in reverse.
