-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   MMCS HDD Unlock -- Success! (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/mmcs-hdd-unlock-success-22994/)
brian360 Oct 23, 2007 11:42 PM
RE: MMCS HDD Unlock -- Success!
ORIGINAL: rcpax
And of course, the long awaited "proper" fix for the DVD playback while in motion.:)
Speaking of which, this website claims to do it for many other OEM navi's. I tried it on the MMCS and it failed though -- should probably get in touch with this guy to see if he can figure anything out about the MMCS
http://www.naviedit.de/
brian360 Oct 23, 2007 11:57 PM
ORIGINAL: evoracer
What does this mean for us? Are you going to utilize this information to install a larger HDD?
Basically, yes. If I run out of room on the music server, I can simply resize the last partition and image it to a larger drive. One thing to keep in mind w/ changing drives though is the drive in the MMCS is an automotive grade drive -- it can withstand insane temperatures and shocks versus normal laptop drives. So a replacement drive will likely fail sooner than the original.
For more information, the MMCS drive is a "TOSHIBA MK3029GAC"
GPSeek Oct 24, 2007 01:08 AM
ORIGINAL: brian360
As I said in the other thread,withstanding low temperature is the key for harddrive automotive application.
Shock is not a big issue for laptop drive either.
rcpax Oct 24, 2007 01:16 AM
Worthy Automotive HDD upgrade? http://www.hitachigst.com/portal/sit...beb82eac4f0a0/
20GB additional space than the current OEM drive capacity
Here's Seagate's offering with 40GB top capacity: http://www.seagate.com/ww/v/index.js...;reqPage=Model
GPSeek Oct 24, 2007 01:45 AM
Seagate40GB ST940813AM
Ambient Temperature
Operating
-30 to 85 degrees C
Nonoperating
-40 to 95 degrees C
$169 from CDW, not bad
http://www.cdw.com/shop/products/spe...ecs-_-Main+Tab
rcpax Oct 24, 2007 02:32 AM
The Hitachi Durastar J4K50 is actually 50GB. But no one is selling it yet?
puddy Oct 24, 2007 03:51 AM
ORIGINAL: brian360
My laptop is being replaced rather than sending it back with my data on itI dropped it really really hard on to concrete 4 times, but it still works!!!
Ended it up sending it back without the hard drive. Now I know my data and password are safe and cannot be recreated
Puddy
antlip Oct 24, 2007 06:40 AM
I dont think I understand 1 word in this trend.
BacDoc Oct 24, 2007 07:48 AM
I think I am smarter now from just opening this thread.
chili_g Oct 24, 2007 10:50 AM
[sm=hail.gif]
I don't even have a MMCS, but props to a damn fine hack!
Want to work on disabling the TPMS in the ECU next?
