MMCS- How to reset GPS/Nav Antenna?
How can I reset my GPS Signal/Nav Antenna?
I tried an Aux in motion bypass and my navigation is off. When I drive the map moves around but it is in the wrong location. Like several towns over.
I'm ditching the aux in motion bypass and want to know how can I reset my GPS signal.
Basically here is what I had done...
Once you have finished splicing your video cables you will be able to view your rear view camera when you REVERSE and in AUX (while stopped). But if you're in AUX and you start moving, the car will sense this and throw up that annoying "AUX IN MOTION". To disable this you need to unplug these wires permanently OR have a switch. The reason for the switch is for you to use the Navigation if you need it. The navi uses the VSS to quickly know you're moving and grab a GPS signal. But you'll have to remember switch it on or off.
find these wires here
once you find them and splice them, get a DPDT switch - I also made another drawing
ryandlor
11-28-2009 04:16 PM
