Mud flaps/guards
Has anyone installed them before?
I couldn't find instructions online before I buy them. What is involved? Wheel stays on? Adhesive? Does it prevent stone chips on the side of the car? |
5 Attachment(s)
They save you from stones (Most of the time)
Instructions |
Where can I get the "primer"?
Thanks |
Easy to install.
Good luck finding the primer. I looked at several auto parts stores with no luck. |
I have been googling rock chips on the doors and rear wheel fender. Actually wasn't able to find a picture. Can anyone point out where do this occur as I am going to be talking to a clear bra installer.
I think it looks better than the mud flaps and it is a little better protection anyway It seems they made the side sill a little bigger so maybe the problem is not as pronounced on the newer models? http://www.mitsubishicars.com/MMNA/o...hite.en-us.jpg |
I got another question..
how do you remove the 3 original clips that are holding the liner in place? Do you press down the middle or something else? |
Originally Posted by OutlanderGT
(Post 285369)
how do you remove the 3 original clips that are holding the liner in place? Do you press down the middle or something else? The bottom part is hollow and split and the center part is a pin that spread this piece and lock it in place. |
