-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   my stereo (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/my-stereo-27719/)
Hertz May 27, 2008 07:11 PM
my stereo
Just wanted to share. Replaced head unit, front speakers. Front doors noise dampened. Took me 2 weekends. This is my first personal installation. I'm satisfied with this one. Will add rear view camera soon.
head unit: kenwood 5120
speakers: polk db 6501
steering wheel controls: pac swi-x
front dash: metra 99-7013
noise buster: dynamat xtreme
[IMG]local://upfiles/16736/5A2BB8F505A246AF97E40D3F898C0590.jpg[/IMG]
[IMG]local://upfiles/16736/D1B609F43D3A4B9C9EFC824A164B5CDD.jpg[/IMG]
[IMG]local://upfiles/16736/5C457FCEF26D4CC29D814214F585D089.jpg[/IMG]
[IMG]local://upfiles/16736/4F035F1FBC5E4E9F8BE101794804850D.jpg[/IMG]
[IMG]local://upfiles/16736/3A9A338B47F141139F2699AE2B85910F.jpg[/IMG]
mightyOUTTIE May 27, 2008 08:58 PM
RE: my stereo
nice super SSLLLEEKK!
goldenboy May 28, 2008 02:04 AM
RE: my stereo
nice touch!
congratulations on the new system
eclipse95blk May 30, 2008 12:21 PM
RE: my stereo
where did u get the wiring codes, or can u give to me
Outie08 May 30, 2008 12:28 PM
RE: my stereo
Nice ! :DThanks for sharing, good pics.
How many bills did that set you back ?
jsrd May 30, 2008 12:39 PM
RE: my stereo
Good job, Hertz. About the Dynamat, that as much improvement the isolation to the interior of the Outie and that as much improvement the listening of the audio? I want to put Dynamat to my Out and your comenatrios will be helpful. . .
willowpeak May 30, 2008 12:59 PM
RE: my stereo
Nice setup... your rocking now.. .
Hertz May 30, 2008 07:36 PM
RE: my stereo
Thanks folks who liked what I did and let me know!
I found radio harness color codes here:
http://www.the12volt.com/installbay/forum_posts.asp?KW=tweeter&TID=98736
Also I've purchased Outlander compatible harness from installer.com, it comes with the same color-codes as the one supplied with kenwood unit. It made matching wires no brainer. The only drawback about harness I got - it does not come with extra pins for steering wheel buttons interface, so I just cut them out.
Below is a quote from the link above:
#513740: 2007 MITSUBISHI OUTLANDER 4DR SUV WITH 3.0L ENGINE AND 6-SPEAKER AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna PINK (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Steering Cntrls OPTIONAL
Speed Cntrl NO
Radio Security YES
Security
Battery YELLOW (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE (+) IGNITION SWITCH HARNESS
Starter 1 ORANGE (+) IGNITION SWITCH HARNESS
All Door Trigger
USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE
Domelight Super YELLOW (-) AT VEHICLE FUSEBOX
LF Latch YELLOW (-) AT MODULE UNDER DRIVER SIDE DASH
RF Latch GREEN (-) AT MODULE UNDER DRIVER SIDE DASH
LR Latch RED (-) AT MODULE UNDER DRIVER SIDE DASH
RR Latch BLACK (-) AT MODULE UNDER DRIVER SIDE DASH
Trunk Trigger WHITE (-) AT MODULE UNDER DRIVER SIDE DASH
Hood Trigger RED/WHITE (-) AT MODULE UNDER DRIVER SIDE DASH
Alarm Disarm GREEN/RED (-) AT VEHICLE FUSEBOX
Alarm Arm GRAY/BLUE (-) AT VEHICLE FUSEBOX
Parking Lights YELLOW & BROWN (+) AT INTERIOR FUSE BOX HARNESS
MUST USE BOTH WIRES AND DIODE ISOLATE EACH WIRE,
Convenience
Headlights-Lo RED/BLACK & ORANGE (+) AT EACH HEADLIGHT
CAN ALSO BE FOUND AT UNDER HOOD FUSE BOX, MAY ALSO BE RED/BLACK & BLUE ON SOME MODELS
All Hazrd Lights GREEN (-) AT MODULE UNDER DRIVER SIDE DASH
Wipers-Lo GREEN (+) AT VEHICLE FUSEBOX
Wipers-Hi BLUE (+) AT VEHICLE FUSEBOX
Parking Brake LIGHT GREEN (-) AT VEHICLE PARKING BRAKE SWITCH
Remote Start
Accessory 1 LIGHT GREEN (+) IGNITION SWITCH HARNESS
Key Sense RED/WHITE (OPEN) IGNITION SWITCH HARNESS
THIS WIRE RESTS AT GROUND AND IS AN OPEN CIRCUIT WITH THE KEY INSERTED
Tachometer GREEN/WHITE (AC) AT INJECTOR #1
ALSO AT ECM MODULE TO DRDIVER SIDE OF AIRCLEANER, PIN #2
Speed Sense WHITE/BLUE (AC) IN HARNESS TO GAUGES
Brake Lights RED (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights WHITE (+) AT VEHICLE FUSEBOX
Horn GREEN (-) AT VEHICLE FUSEBOX
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock RED/YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL
PowerLock WHITE/BLACK (-) IN HARNESS IN DRIVERS KICKPANEL
LF Window Up VIOLET (REV) AT DRIVER WINDOW SWITCH
LF Window Dn ORANGE (REV) AT DRIVER WINDOW SWITCH
RF Window Up BLUE/WHITE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RF Window Dn GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Up WHITE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Dn BLUE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RR Window Up GRAY (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RR Window Dn YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Hertz May 30, 2008 07:44 PM
RE: my stereo
Covering front doors only with dynamat did not make any difference in terms of reducing road noise. I'm planning to do floor, trunk and back doors with it. Hope it will make a difference.
However it has modified the sound of stereo. Good side - it became more articulated so vocal is now very clear and near to perfect. Bad news - it created kind of closed box for speakers, so response from mid-bass is significantly reduced.
Think twice if you don't have sub and like bass.
ps
note - speakers are placed on mdf rings. it has played it's role also
eclipse95blk May 30, 2008 07:46 PM
RE: my stereo
do u have a RF system. if so how did u turn on stock amp
