my stereo
Old May 30, 2008 | 08:04 PM
Hertz's Avatar
Default RE: my stereo
no, I didn't have RF
ORIGINAL: eclipse95blk
do u have a RF system. if so how did u turn on stock amp
Old May 30, 2008 | 11:49 PM
jsrd's Avatar
Hertz, great info, thanks for your reponse. And excellent information of the harness color code, it will be helpful. . .
Old Jun 4, 2008 | 09:38 PM
klaviermann's Avatar
can you still control volume and track with the steering wheel buttons?
Old Jun 4, 2008 | 09:54 PM
Hertz's Avatar
ORIGINAL: klaviermann
Yes, I do. I was able to program all 8 buttons on steering wheel for whatever function is supported by head unit. Obviously volume and track control first of all. Picture #5 shous IR light mounted on a dash. This isPAC SWI-X unit:
http://www.pac-audio.com/products/pr...el%20Interface
the only draw back with it - is noticeable delay between pushing the button and actual action to take place. Still acceptable.
Old Jun 20, 2008 | 10:50 AM
akdenver's Avatar
Hertz, you do not mention bluetooth. I noticed there is blutooth interface for your stereo: http://www.amazon.com/Bluetooth-KCA-...317&sr=1-2
From your experience, do you think it will be possible tohook upthe BT buttons on the steering wheel in your setup?
Thanks.
Old Jun 20, 2008 | 11:23 AM
Hertz's Avatar
ORIGINAL: akdenver
I did not install bluetooth module.
Basicaly SWI-X mentioned above will allow you to program any of 8 steering wheel buttons to correspond whatever buttion is on IRremote controller to head unit. According to manual, it would be possible to program buttons to answer the call and drop it. But I don't think it would be possible to start voice-recognition dial by pressing only one button on a wheel. Even so it is supported by head-unit equipped with module you gave a link to, voice-recognition dial is accessed through series of commands.And SWI-X does not support serialisation - reproducing sequence of commands.
PS
update to noise bustering with dynamatt.
dumpening all 4 doors made a difference. the end result is still not ideal but far better then doing front doors only.
Old Jun 20, 2008 | 03:03 PM
akdenver's Avatar
Thanks, Hertz. One more question: what is the part number of that harness you got from installer.com? I got lost there.
Old Jun 20, 2008 | 03:27 PM
Hertz's Avatar
Itis METRA 70-7005. Fits Outlander 07 also:
http://www.installer.com/item/displa...php?it=70-7005
Unfortunatly this harnesshas no pins for remote control. Had to cut SWI-X wires directly.
ORIGINAL: akdenver
Old Jun 20, 2008 | 10:46 PM
akdenver's Avatar
Thanks again. Speaking of remote control:did you see thiswired one: PAC SWI-JACK, which seems to be compatible: http://www.crutchfield.com/App/Produ...CK&tp=3405
What do you think?
Old Jun 23, 2008 | 07:35 AM
puddy's Avatar
While you have the door trim apart you can take the option of spraying rust proofing inside the door cavities for extra rust protection
puddy
