NEED HELP! DRL
I have been trying to figure this out forever now. I havent tried anything , but noone seems to know the answer. I have a 06 outlander, and it has drl's. How do i uninstall them or disconnect them. I would like to get hid's and i need to figure out how to disable the drls so that way i dont have to have the hid's on all the time....any help would be appreciated thanks!
RE: NEED HELP! DRL
take the bulbs out...the fuse....when you put the HID's in have them day out the lights. Does the pull up the E-Brake on notch work?
RE: NEED HELP! DRL
i didnt quite understand that completely......pulling up the ebrake does nothing.....where is the fuse i have to disconnect?? or what is it exactly i have to do
RE: NEED HELP! DRL
On some cars..you can pull up the E-Brake one notch and the lights go out but the brake does not go on. Look into what fuse it is for the DRL..I'm sure you can find it or just take the bulbs out. If you are having HID's put in I'm sure who ever is going to do it will be able to help you.
