Need help with non-starting 2006 4G69
Hello,
I have been trying to help my neighbor start his outlander. He parked it at work and when he went to leave, it started, then died after a couple of minutes of idling. The fuel pump is working, I took the fuel line off at the elbow under the hood and when he cranked it, fuel squirted out. It also will sputter if we shoot starter fluid into the throttle body. So could it be the fuel injectors? Did they all happen to go bad at once, or is there a fuse that covers them? Is there anything else I should look at?
Thank you!
Thank you!
jhun35
05-22-2012 12:39 PM
