Need OEM Air Filter #
Old 07-02-2009, 09:17 AM
Printerman's Avatar
Red face Need OEM Air Filter #
Hi All:
I tried to do a search but could not find the part number for the oem engine air filter for the 2007 Outi with a V6 engine...
Thanks for your help....
Old 07-02-2009, 02:20 PM
azjake's Avatar
When I've went to auto parts stores like AutoZone, Checker, etc and looked in the Fram or STP books they have by the filters all I can find is info on oil filters, but no air filters, or cabin filters for the V6 or 2.4L 4 cylinder outties. Once someone finds this information for both engines we should put it at the top of the forum so members can refer to it.
Old 07-02-2009, 04:34 PM
ruchuck's Avatar
check out pureoil.com
I could not find the one at Advance but got one that fit the nissan sentra which was the same size, give or take a 1/16 of an inch
Purolator C35530
________
Toyota Motor Engineering & Manufacturing North America history
Old 07-02-2009, 06:04 PM
jsrd's Avatar
Originally Posted by printerman
i tried to do a search but could not find the part number for the oem engine air filter for the 2007 outi with a v6 engine...
It's 1500A023. . .
Old 07-02-2009, 07:17 PM
azjake's Avatar
Thanks ruchuck. I went to pureoil.com typed in 08 outlander and its showing C25859 as the cabin filter for both the 4cyl and V6. PL14610 for the oil filter for both engines, A35244 as the air filter for the 4cyl and for the 6 cyl A35789. This is for the Purolator brand of filters.
Here's the link to the purolator page; http://www.purolatorautofilters.net/...nder&year=2008
Old 07-03-2009, 07:51 AM
Printerman's Avatar
Angry
Thanks all:::
I bought two from JC Whitney and had to send them back.......
Old 07-04-2009, 09:20 PM
ruchuck's Avatar
azjake,
the C25859 has been hard to find. That is why i went with the other one
________
Toyota Motor Manufacturing Canada specifications
Old 07-05-2009, 10:40 AM
azjake's Avatar
Thanks for the heads up. Maybe what I will do is call one of the auto parts stores that carry purolator and see if they can order a couple for me. If they can't get it, then I will go with the other one.
Old 07-05-2009, 11:03 PM
alim's Avatar
I've posted some of this info on another thread but here it is again:
cabin filter: very cheap only $5.00 each. I've been using it and it's really very high quallity.
http://www.logical-source.com/MITSUB...OUTLANDER.html
I also use the k&n drop-in filter. By the brand there's nothing else to be said about quality.
http://www.knfilters.com/search/prod...x?Prod=33-2392
Old 07-13-2009, 02:58 PM
brianwis's Avatar
If you have an AutoZone in your area, their website lists and STP brand, part # SA10497
for $17.99
Quick Reply: Need OEM Air Filter #
