Need your Comment
When I change tires to for my winter tires I notice that one of the oem tire as a screw in it so I'm debating getting it fix with a plug or just get better tire like the Toyo Versado LX. I'm just afraid that if I get the tire fix that It wont hold if I pull an heavy load with the trailer and all end up again with a flat tire.
RE: Need your Comment
Hi Roach,
In my 23 years of driving and at least 4,5 plugs, I have never seen one let out. I don't think you have anything to worry about. Cheers... Dan |
take it to a tire shop that will remove the tire from the rim and patch the puncture from the inside.
this type of repair "permanent". |
ORIGINAL: 07outty take it to a tire shop that will remove the tire from the rim and patch the puncture from the inside. this type of repair "permanent". |
I find that the OEM tires are not great, but they're not bad either. I've researched the tires before buying the car, mainy because I want to know how much $$$ I would need to fork out to replace the 18" tires, and the bigest complaints I've read about the Goodyears we have, is that they appear to have poor quality control, but if the set you have are ok, than you are fine.
They are definatly not snow tires, but you already have a set of those. I would just use them up. You would spend close to $1000 to get new ones. |
As long as the screw isn't too wide the patch should hold, evenwhen towing.
Any hole bigger than 1/4" or so cannot be repaired reliably and the tire shop will advise you to buy a new tire. In that case it might be better to just leave the screw in like dekodan. |
I called whenI got home the tire shop and the guy said that the patch that they apply by the inside should be good to fix it and it's only 19$ instead of 860$ tax in and install for the toyo versado so I will go with the repair and use the tire untile there done and by the time I get a new set they might have a better performance tire in are rare size that mitsu pick out.
Try the patch and if it fails use the road side assistance. I also got a rim and tire warrenty, I dont know what it covers for tires. I got it for the rim part mainly since there so damn expensive.
The 18" rims are over $600 a piece from the dealer.
ORIGINAL: bnilguy The 18" rims are over $600 a piece from the dealer. |
