No AUX option on MMCS Mode
Old 06-06-2009, 05:38 PM
jsrd's Avatar
Originally Posted by ginofanti
Thank you I connected AUX too on my car!!!
I'm italian and I had C-crosser with same problem : no AUX connection.
With your thread I solved my problem.
The important connection is 10 - 17 on D123 to switch on the AUX option on MMCS.
Thank you yet.
ps. sorry for my bad English
Great news, and and excellent contribution about ground connection in D-123
  #22
Old 06-23-2009, 05:09 PM
titto's Avatar
hello,
i need your help.
i've a pajero '07 new model instyle with rear camera. Is possible for you add Input signals ( Audio and Video) to my MMCS. i read several topics in this forum, but is not cleary all connections.
first info whic socket in MMCS is for the rear camera
many thanks for any kind of information.
  #23
Old 06-24-2009, 05:15 AM
jsrd's Avatar
Hi titto. Yes, it's possible. Look here,
https://mitsubishiforum.com/forum/sh...t=doublecheese
doublecheese and rdenis have the solution for your Pajero. . .
  #24
Old 06-24-2009, 08:24 AM
titto's Avatar
Many thsnks for your reply..
so the cable in the back of my pajero near the subwoofer if the Audio in/Out where i can connect my ipod?
do you think that i need also the vtr harness to enable the aux botton in my MMCS?
ciao
  #25
Old 06-25-2009, 05:35 AM
doctorC's Avatar
Default RES connections
Originally Posted by jsrd
Wow stef48, you removed the D-123 harness, nice. Can you to make one pic from opposite side of harnessr?
Don't worry, all is 0k. D-123 has 24 pines, and 18 wires conected.
So, this is the order of wires
Now, you need to unit in D-123 the next pines to send the signal from AUX inputs to MMCS:
(blue)20-1(green) ~ video IN
(yellow-green)21-2(yellow-black) ~ ground video IN
(black)22-3(brown) audio R IN
(white)23-4(yellow) ~ audio L(mono) IN
(lightgreen)24-5(black-white) ~ ground audio L/R
(red-green)17-10(black) ~ ground system
NOTE: Before you make the unions in D-123, tries to check continuity between C-117 and D-123 (1-20 / 2-21 / 6-22 / 4-23 / 5-24) terminals
Good Luck
JSRD
Does this harness has also the connections for the RES connection?
You wrote that the D123 houses 18 wires but you named only 12 of them!!!
Can I suppose that the 4 missing are the video in video out and audio from RES to MMC and vice versa?
  #26
Old 06-25-2009, 04:39 PM
jsrd's Avatar
I don't know about it, sorry, so you must check if is present or not prewiring, but by doublecheese's post, seems that AUX inputs ONLY are available for Pajero models that mounts the RES. . .
It's unnecessary for Pajero models
  #27
Old 06-25-2009, 04:46 PM
jsrd's Avatar
Originally Posted by doctorC
JSRD
1. Yes
2. This is because we ONLY needed to connect the AUX inputs
3. I will to check about other 6 wires
  #28
Old 06-25-2009, 05:23 PM
doctorC's Avatar
Default Res connection
1. Yes
2. This is because we ONLY wanted to connect the AUX inputs
RES connections provide a VIDEO OUT lead which is very important as you can use this to connect an aftermarket RES so that all systems play the same video with AUDIO comming from existing Mitsubishi amplifier...
Actually the 6 missing wires should be video in-out shield plus audio R+L from RES to MMC (RES doesn't have audio inputs as audio plays through MMC speakers in every case..)
  #29
Old 06-26-2009, 04:08 AM
jsrd's Avatar
doctorC, here is the other 6 wires:
6 - red - video In/Out
7 - violet - ground video
11 - red/white - power supply constant to RES
15 - blue - communication RES~MMCS (active Rear Display button in MMCS)
18 - green/white - to combination meter
19 - yellow - power supply with switch to RES
  #30
Old 06-26-2009, 07:00 AM
doctorC's Avatar
jsrd thank you
The KEY wire is the blue-15 which should toggle the RES button in MMC (most probably by grounding it?)
Are you sure for the rest of the wires? THERE SHOULD BE at least two wires that should carry audio R/L to MMC otherwise RES video would be without audio for the front MMC viewing passengers....
Quick Reply: No AUX option on MMCS Mode
