OEM Tow hitch wiring harness (MZ314612)
Has anyone installed a Mitsubishi Tow hitch wiring harnesses? I'm wondering if you only have to plug it into the tail light connections or if you still have to run a wire through the car to the battery.
Originally Posted by Kazper
(Post 326925)
I just did a Curt hitch and wiring harness install on my 2018 Outlander PHEV. The wiring plugged right into the factory socket. I had to run a hot and ground, but since there is a battery in the back it was easy. I didn't drill a hole, I'll just run the wire under the hatch when I need it. The Curt hitch was an easy bolt on; no need to remove the bumper.
