Outalnader Engine Immobilizer
Old 01-02-2009 | 12:39 AM
goldenboy's Avatar
Default Outalnader Engine Immobilizer
anybody care to elaborate what this "really"does?
ive always had the impression that the EI shuts off the engine if and when the car gets jacked.
am i right?
thanks
Old 01-02-2009 | 01:25 AM
macuis's Avatar
Default RE: Outalnader Engine Immobilizer
EI doesn't permit the engine to start if key is not there.
Old 01-02-2009 | 01:41 PM
azjake's Avatar
The key transmits a unique code (unique just to your vehicle) that allows the engine to start. If the code is not transmitted the engine doesn't start. Think of it in the same terms as a garage door opener that transmits a unique code to open your garage door.
What this means is if you lose one of your keys you can not just take your other key to a hardware store to have a duplicate made. It won'tstart your vehiclebecause the duplicate key does not transmit the code. If you losea key you mustgo to a mitsu dealer to have another key made that transmits your unique code.
Old 01-02-2009 | 02:24 PM
Wheeldog's Avatar
If the car is running to start with, the car can still get jacked and will keep running without the FAST key, but the next time it gets turned off it will not be able to be re-started. Similarly, if you're driving down the road and throw the FAST key out the window the warning chimes will sound to tell you that the key is missing, but the engine will not stall.
I had the same question when I bought my Outlander- if I have this wrong, somebody please correct me.
Old 01-02-2009 | 05:22 PM
azjake's Avatar
It makes sense to me if your vehicle is already started, it will continue to run no matter what happens to the key.Think whatcould happen if your driving down the freeway at 65-70 mph with cars right behind you and suddenly with no warning your engine quits and you stop abruptly. Big accident!!!
Old 01-03-2009 | 04:45 PM
goldenboy's Avatar
got it...thanks guys
ryguy2503
03-04-2012 06:49 PM
grandis2010user
07-17-2011 09:36 PM
alclot
01-20-2011 10:30 PM
jsfirebird
08-12-2010 07:28 AM
jsfirebird
04-12-2010 07:26 PM
Quick Reply: Outalnader Engine Immobilizer
