Outlander 2007
Hey.
I have an outlander from 2007, a 2.0 diesel. It often goes into limp mode. I also think it uses a lot of diesel, I can only get it up to about 10 km/l or about 25 miles per gallon. I just installed a brand new turbo when I thought it was the problem, but it didn't help anything. Does anyone have a suggestion for what to try next? |
I have just had the same issue with my 2008. Turned out to be the Boost Pressure sensor. £25 from VAG. My average is now 44 to the gallon on a motorway run.
Originally Posted by Matt101
(Post 326988)
Did your fuel consumption improve after the sensor was changed? Do you know where it is located on the car? |
https://cimg7.ibsrv.net/gimg/mitsubi...1d1b3007ff.jpg
Hope this helps |
Originally Posted by Jes Bouet
(Post 326992)
Thanks for reply.
(Post 327012)
Yes and see above
I hope this is the problem, because the engine will soon drive me crazy. |
I have now changed the sensor, it has not changed anything.
I can still only get it up to 25 miles per gallon Max. It smokes a lot when it accelerates, it must get too much diesel, or too little air? |
Have you got a code reader. Sounds like a fuelling issue. Especially the smoke part. I can ask my mechanic if he has any ideas he can throw your way
(Post 327042)
I have now changed the fuelfilter and airfilter, but also it was without result. |
(Post 327011)
Hope this helps |
