RE: Outlander Lowering Springs
Road Race is interested in seeing if the Progress springs they run on their rally cars will be appropriate on my car, but I don't have the money for them right now. I will try to call them tomorrow and see where this will go. I was thinking later on in the year I'd do the springs, but I know they would make the car look so much better...the wheel well gap is just HUGE!
hmmmm...maybe. w/ light chassis, er' almost a lancer s.u.v. why not huh??[:-]
If I can find one suitable for the Lancer Sportback, I think I'll be set. The Progress springs are about $190, so I'll keep it in the back of my mind for a while. Damn, everything ($) adds up quickly with cars[:@]
hey, did you know that high flow cat for lancer works for outlander?? i, e-mailed road race and asked about it. well its good to hear that thing will perform for outlander...nice!!! am' getting one next wk.!!!;)
high flow cat sounds nice have to check on that
ORIGINAL: wicked_outlander hey, did you know that high flow cat for lancer works for outlander?? i, e-mailed road race and asked about it. well its good to hear that thing will perform for outlander...nice!!! am' getting one next wk.!!!;) |
awwweeee you!!!!![:@] how is it??? any changes??? (yeah for sure, but what about torque??) does it come w/ O2 sensor?? i, need to find out all this, before i, start w/ it.
your o2 will hook up to it, you may need the adapter though, I'm 99% sure they installed it on mine. When you order it they should tell you, if not, pm me and I'll check mine to see if there's an adapter on the cat.
I had the header, downpipe and high-flow all installed at the same time, so I noticed it went through the RPm's easier and likes the mid range rpm's better too. It also seem that I don't need to step on the gas as far to go the same speeds as before. |
ORIGINAL: dirtwagon your o2 will hook up to it, you may need the adapter though, I'm 99% sure they installed it on mine. When you order it they should tell you, if not, pm me and I'll check mine to see if there's an adapter on the cat. I had the header, downpipe and high-flow all installed at the same time, so I noticed it went through the RPm's easier and likes the mid range rpm's better too. It also seem that I don't need to step on the gas as far to go the same speeds as before. |
The adapter in reference is for the o2 sensor. The cat should be a 2/1/4, so it'll just weld right up. Yes...WELD.
