Outlander Suspension upgrades
#41
#42
#43
what about longer coil springs?
instead of lowering my outie, i would like to go the other direction and lift it 2 in or so.
what do u guys think about getting longer coil springs?
as supposed to just buying those cheap polyurethane spacers
(like daystar, mr gasket, etc)
pros vs cons?
obviously the springs have to be custom made (currently working with mike @ coilsprings.com about this).
will i need to upgrade to longer shocks as well?
the spring stiffness/softness can be adjusted to what i want, so ride comfort shouldn't be an issue... i hope.
what about installation?
front - is it basically just removing the strut assembly / take out stock spring / replace with custom spring / screw assembly back in?
rear - since the coil is separate from the shock, can i just jack up the rear / use compressor to remove stock coil / put new (compressed) one in / decompress / lower rear end back to ground?
THANK YOU ALL FOR ANY ADVICE / OPINIONS = )
pros vs cons?
#45
I know I am late to the party on this thread but thought I would provide some insight. I did a lot of research on the topic, as we know, there is not a lot out there.
I have installed BC Racing Coilovers on my 08 Outlander XLS. (BR-B27). I went with the BC's over KW's due to availability and previous experience with BC Racing Coils.
The ride is firmer than OEM but improved. NOTE: All of my vehicles have been lowered, so I am used to the overall differences in feel.
The Coils are 30 way adjustable. I have mine set fairly soft (+4 to all 4 corners) and the ride is good. Any harshness felt in bumps is actually attributed to my tires and the low profile (35s). I will be upsizing to 40 series next spring - this rubber was cheap with the wheel purchase.
Rear Suspension: my 08 came with the OEM Coil Spring and separate Struts. As per the manufacturer. My kit came with true coilovers, front and rear. When the rear coilovers are installed, the OEM Coil Spring is removed and discarded (keep for reinstall later, if you like).
Front end install: Note, while you're at it, buy new stabilizer link ends, as the OEM ones will be rusted and not reusable - I actually had to cut the OEM's off due to the hex end being stripped. New ones are $30 each typically. Anyway, I have photos in the 2G Outlander Coilover thread. (EDIT - MY BAD... That thread is on another forum. Pics below)
Hope this helps.
Hope this helps.
#47
Yes, It is a 2G specific kit from BC Racing. BC Racing BR Series Coilovers 07-13 Mitsubishi OUTLANDER - CW6W. Part No. B-27-BR.
From all my research, it was between this and the KW Var. 2.
