Outlander trouble codes P0335 & P0340 help!
Old Oct 28, 2010 | 07:51 AM
rascosss's Avatar
Default Outlander trouble codes P0335 & P0340 help!
Hello, I have a MIT Outlander 2003. I've had to recently replace the head & water pump...all was well to about a month later then the P0335 and P0340 trouble codes came on. I replaced the crank shaft sensor and the camshaft sensor and the camshaft angle sensor and still lights. Was told could be timing off causing problems...readjusted the timing in which i was off one tooth...still the lights stay on! The car runs fine otherwise but will not pass inspection (due Oct 31st) with these lights on...I am at my wits end trying to figure this out. thank you....
CaptainDon
Nov 16, 2013 02:43 PM
slavao
Feb 2, 2012 06:55 PM
Shepard69
May 20, 2011 08:50 PM
05-6G72
Oct 20, 2010 08:51 PM
Rob
Jan 8, 2008 05:58 PM
