Pictures needed!
HELP!!
does anyone have a picture of mitsubishi's 6 cd changer (the backside) that comes with the 650 watt rockfosgate? I need to know if i can hook up an RCA cable from there for my mono amp. Does it have an RCA in the back or do i need an in line converter?
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html
okay thanksss! do you have a picture or diagram showing that?i want to make sure i splice the right wire
I know I probably should have taken a pic when I saw the back of the car all torn apart. I'll ask the guy who did the work to see which wires he tapped for the line output converter. I'll get back with you.
thank you i would greatly appreciate it! and i would need a inline converter like this one correct?
http://www.crutchfield.com/p_161LC2I...tput+converter
AudioControl LC2i 2-channel line output converter for adding amps to your factory system at Crutchfield.com
![Wink](https://mitsubishiforum.com/forum/images/smilies/wink.gif)
so true! I have this set up for a subwoofer and also a head unit.. but they are so expensive.. I wonder if i can install the new head unit myself, i kno they have a harness i need to buy, i know what theoretically i need to do, but when it comes down to it, i dont kno if i can make it all work flawlessly =/
