problem with cruise control
Hello my Friends from Greece
Please I want your help. I have owned only for two weeks my new mitsubishi outlander 2007 2.4L Petrol , but i have problem with the cruise control.I tried everything! I press the "on-off" button but nothing!, even the "cruise" signal don't turn on!! Just dead! Any suggestion I read the owner manual but i can't find something usefull Thank You in Advance |
RE: problem with cruise control
When you press the "on-off" button and the "Cruise" light in the gauge cluster does not come on, then there is a problem. Possibly a fuse. Check the manual to see if it tells what fuse is in control of the cruise control. Otherwise take it to the dealer... hopefully its not an electical problem.
I have checked the owner manual, but there in nothing there about what fuse is responsible for cruise control system.
And the worst off all is that the technical department of the dealer (official represantive in Greece) it's not very familiar with these kind of problem, first reaction of the technical manager was: Just Try to turn off the ACS!!!!! That's why i need your help I almost forget, thank you for your response... |
Cruise can run at minimum speed about 40...60 km/h.Howfast youdrovewhen you tried to set cruise ON?
ASC can't disable cruise function of course. |
ORIGINAL: embolaras Hello my Friends from Greece Please I want your help. I have owned only for two weeks my new mitsubishi outlander 2007 2.4L Petrol , but i have problem with the cruise control.I tried everything! I press the "on-off" button but nothing!, even the "cruise" signal don't turn on!! Just dead! Any suggestion I read the owner manual but i can't find something usefull Thank You in Advance |
ela re patriwti !!! To exw pa8ei kai egw..den energopoiountan to cruise me to diakopti on/off.Bgale ton polo ton arnitiko tis mpatarias kai merika lepta kai meta ola enta3ei.(den xaneis tis ru8miseis pou exeis kanei)
The cruise control system just needs a reset.You can achieve that by disconnecting the negative pole from the battery for a few minutes.This action would not affect your car settings.
Yannie you are right!!
I disconnect the negative pole and everything is allright, the "cruise" indication turn on! Do you know why this happen, any ideas.... Thank you very much. Patrida athanati! |
I'm beginning to think that a major american software / OS company designed the electronocs for the Outlander. This now makesa satellite error on the Sirius Radioand a cruise control error both fixed by "rebooting" the whole system!
My wife had a Dodge Caravan, that used to have a similar problem with the power door lock. It had a auto-reseting breaker that would reset when power was removed. However it did not need to have the battery pole removed,it had a fuse that you could just pull out and in to do the reset, this fuse was described as a fuse that you should remove when storing the vehicle for a long time, I assume these types of breaker continously draw a small amount of current, and that's why they have the fuse.
| All times are GMT -5. The time now is 06:08 AM. |
