Puncture Seal Safe for TPMS?
Old May 9, 2008 | 10:23 PM
Outie08's Avatar
Default Puncture Seal Safe for TPMS?
I was wondering if the use of puncture seal in a can will harm or damage the TPMS module? Does anyone have any prior experience to share?
[IMG]local://upfiles/16364/C8A79B3540B74D188AAF6B7B85CE4E96.jpg[/IMG]
Old May 10, 2008 | 08:29 AM
Manybrews's Avatar
Default RE: Puncture Seal Safe for TPMS?
absolutly NOT. Its not safe for ANY part of the tire.
never, EVER use it. its pure crap.
Old May 10, 2008 | 12:05 PM
2g0s0r1's Avatar
Ive used it on a 2002 Tundra and a 2001 Integra, WORKED GREAT! Filled up the tire so i could drive off. I got the tire fixed/replaced a couple days later both times, as it is a temporary fix. It will get you out of a jam for small leaks and punctures.
HOWEVER, I am almost positive it will damage the TPMS sensor. It will get coated in a foamy glue and probably will need to be replaced. It could be cheaper then a Tow Truck depending on you situation at the time. Or use your spare.
Old May 10, 2008 | 02:40 PM
Manybrews's Avatar
As I said, it is horrible, horrible stuff.
the spare is there for a reason. use it.
Old May 10, 2008 | 08:11 PM
Outie08's Avatar
I kind of suspect the sealantwill damage the TPMS sensor at the very least.
I agree a spare or even a towcould be cheaper then replacing the sensor.
That beg the question: Will water orexcessive moisture somehow got inside your tire willalso threaten the TPMS sensor??
You would think the sensor should be water proof..
[IMG]local://upfiles/16364/E7027EAA5B8C4B5891D40A2B2754AD5F.jpg[/IMG]
Old May 10, 2008 | 08:31 PM
evoracer's Avatar
Tire fix-a-flat is horrible for TPMS or not. It WILL ruin a TPMS sensor, and can throw off the balance of a wheel even if you have the tire repaired soon. Most tire shops will charge extra (or even ignore the crap) to remove it from the wheel, as it can actually cake on and become VERY dificult to remove. WORST CASE SCENARIO tool. As stated above, use your spare.
sohcej1
Dec 23, 2005 12:50 PM
big_will
Nov 2, 2005 10:06 PM
turbobird14
Aug 8, 2005 10:37 PM
1998blackgst 240
Apr 19, 2005 08:01 PM
Tmann26
Dec 2, 2004 09:55 PM
