regular gas
Well I've been using premium since I got the thing and I read here that regular is ok.. I can never find the gas cap release and accidentally popped the hood first...
So I was outside in the freezing cold trying to locate the catch on the hood to close it and the attendant asks me what I need so being somewhat flustered I reverted to my "fill of regular" I was used to saying for over 10 years...needless to say it wasn't till I paid that I realized what I did.. so now I have more than 3/4 of a tank of regular.. reading here lead me not to panic and so far I haven't noticed anything at all...with the bad weather I haven't been pushing it very hard so if it was performing worse than usual I likely wouldn't notice it...
Anyway if I notice anything adverse I'll post back but I don't expect anything bad to happen.
run what is in your owner's manual.
if it says to use premium, you'll get more power out of it. if it says to use premium and you put regular in it, then it'll be okay as the engine will retard timing to prevent knock...reducing power output.
if it says to use regular...use that. Premium's higher octane only purpose is to make it harder to ignite for higher compression engines. So running that in an engine tuned for regular fuel would be incorrect. will it work, sure...but it won't be efficient.
They "recommend" premium on the tank and manual bit don't require it.
I haven't really pushed it hard enough to tell if it's giving me less power (or how much) if it ever warms up I'll have to experiment but I think for the winter at least regular will be fine...
Vad: that's a long time to run on regular, that will save me a little money then...
The 6cyl engine is higher compression so premium is recommended but I've been on regular for a few tanks now though and it's fine.
